Help - Engine idle rough and revs not smooth
AJ
Postby AJ » Mon Sep 10, 2007 8:52 pm
probly wouldn't notice the power drop in an NA6 anyway :P :P
/me runs away :shock: :lol:
XMX5 Rogues
NMX516
Postby NMX516 » Mon Sep 10, 2007 9:51 pm
Quite possibly Fatty...
AJ, ever the shite stirrer :roll: :lol:
Philip Lee
Postby Philip Lee » Tue Sep 11, 2007 8:18 pm
thanks guys for your suggestion.
the AFM was installed the correct way (ie. the black bit up).
replaced with another AFM and ECU, still the same.
reconnected the AFC which makes the problem worse.....
i'm completely lost.......
will get professional help.
ampz
Vehicle: NA6 - Turbo
Postby ampz » Tue Sep 11, 2007 11:57 pm
I'm surious to see what the problem would be.
From the looks of the diagram the only way it would modify the fuel signal would be to modify the AFM signal (ie there doesn'e seem to be enough info that it inersects the PW of your injector banks).
I would hazard a guess that maybe (depending on where the cuts to your harness where made) there has been a wire either crossed or the ground is somehow not enough of a short circuit now.
A vacuum leak (to answer your earlier post) can be any vacuum hose loose or unplugged causing erratic idle.
I hope you didn't fry your ignitor as they are quite fragile and the source of that rpm signal your diagram shows... That pin is only a 1V supply to your Tacho (via the ignitor) so seeing a 12V spike (just with the ground disconnected, the ECU may have hunted for a ground via the Tacho, maybe).
Huh?
Philip Lee
Postby Philip Lee » Wed Sep 12, 2007 9:47 am
ampz wrote:I would hazard a guess that maybe (depending on where the cuts to your harness where made) there has been a wire either crossed or the ground is somehow not enough of a short circuit now.
thanks ampz.
i'd think the most likely cause would be a wire is shorted and fired up something which i dunno.
i doubt it's vacuum leak cos it's not just idle. it's blowing black smoke big time after 2000rpm.
we pulled out the plug and all 4 of them are black. not sure if it's caused by normal use or by the current problem.
Postby bruce » Wed Sep 12, 2007 10:30 am
Howabout disconnecting the battery overnight? (Not sure if that's any better than 90 mins though???)
Philip Lee
Postby Philip Lee » Wed Sep 12, 2007 10:32 am
bruce wrote:Howabout disconnecting the battery overnight? (Not sure if that's any better than 90 mins though???)
thanks bruce.
that was done on Saturday night/Sunday morning. a mechanic is looking at the car now.
Philip Lee
Postby Philip Lee » Wed Sep 12, 2007 12:17 pm
carsokay,
thanks for your tip.
i know what you mean about the fine-wire braid. i dun think those touch the signal wire. but i'll check it again to make sure.
thanks
Philip
Philip Lee
Postby Philip Lee » Wed Sep 12, 2007 12:19 pm
latest update:
the mechanic checked the ECU and it's reporting a fault with AFM.
we have since tried 5 other ones and still the same problem......
might now check what carsokay offered.
