Which ECU.
- Novice1
Which ECU.
Have just had Tighe cams installed and cam gears installed on my 99 mx5. Has full lock stewart exhaust system and cold air intake, lightened flywheel and heavy duty clutch.
Idles around 1500, a bit lumpy, but noticeable jump in perfomance mid range and top end.
In order to get the most out of these cams (805), what aftermarket engeine management system would be best. Budget stretches to around $2000.
Lastly, any recommendations for installing, tuning same in BRISBANE.
Novice1 aka Ron
Novice1 aka Ron
- 16bit
- Steampunk
Novice, there's a mob on the northside (eithe Kallangur or Clontarf or maybe even further north).
I can't for the life of me remember the name. It's something like Redline something something. Maybe someone on this forum will know.
The shop specialises in Wolf EMS and he has done several BP engines in 323s/Familias.
If the GC is easily accessible for you, then go for Chiptorque.
Otherwise, pick an aftermarket ems that you fancy, ring the head-office and ask wheren an authorised installer/tuner is.
There is also the DIY Jaycar DFA (Digital Fuel Adjuster) that several ppl on the forum rave about. Ask Fatty and green_comet.
- green_comet
- Car Detailing Guru
- fastfreddygassit
- Waitin' for a mate
green_comet wrote:You should read up on the Megasquirt plug and play. It will be around $900 landed, install is a breeze. You can even remove the MX5's restrictive MAF, and use the Megasquirts onboard MAP sensor. Then with the left over money, you can get a really good tune done.
Thats what I am going to do..if I can't sell my car and I end up putting hot cams etc in it instead
*edited for truth*
Hmm there could be problems with the NB motor I believe with running some computers that people are recommending here. Supposed they have a wierd CAS signal out of them that isn't easy to work with.
Haltech is the best bang for buck on the market currently, but again I'm not certain they can run the later model engines. I'd email them to find out, most people I've heard who have dealt with as far as questions and answers go have been happy with the advice given though I have no first hand experience with dealing with them.
'92, Red, Hardtop, Noisy CAI, Even more Noisy Exhaust, AVO Shocks with TJR Springs (Not so Fuli drifto speco).
- green_comet
fastfreddygassit wrote:green_comet wrote:You should read up on the Megasquirt plug and play. It will be around $900 landed, install is a breeze. You can even remove the MX5's restrictive MAF, and use the Megasquirts onboard MAP sensor. Then with the left over money, you can get a really good tune done.
*edited for truth*
Actually I forgot it was an NB, the Megasquirt plug and plays are only for NA6's, and NA8's soo far.
- Fra66L
Thanks J! I think I'm being referred to here. The Motec standalone was AWESOME when I was up it (embarrased a few cars I had no right to) but terrible the rest of the time....
I've got mine booked in at Allstar Tuning for a haltech miniceptor tomorrow. It's quite a sofistimacated interceptor (paradox?). This is to compliment the new Tighe Cams 805c (or similar) cams that went in over the weekend. I'll let you know how it turns out.
Ron, do you have a noticeable increase in lifter noise with the new cams. Mine sounds a bit like a twin-cam tractor at the moment. Hoping it settles down after a few Ks....
cheers,
T
cheers,
T
The Green Meanie - Grace Green NB8A
Veilside - It's Japanese for UGRY!
- Novice1
[quote="Fra66L"]Thanks J! I think I'm being referred to here. The Motec standalone was AWESOME when I was up it (embarrased a few cars I had no right to) but terrible the rest of the time....
Can't say I have noticed any increase in engine noises. Major thing is watching it fluctuate at idle from 1000-1500 revs. The car tends to shake from side to side.
It doesn't like starting on first turn of the key and it doesn't like taking off straight away after starting. I, was told the A/C might not work as efficiently, but having just tried it, no problems noticed.
I, will speak to John Kraschnefski and John Whittaker re their recommendations.
cheers,
Ron
cheers,
Ron
- Novice1
re Ecu
Thanks guys, I did read all your replies.
Chip torque is a definite possibility, heard good things about them.
Will also talk to John Kraschnefski and John Whittaker re their suggestions.
Keep you informed.
Novice1 aka Ron
Keep you informed.
Novice1 aka Ron
yes as mentioned i really like the jaycar dfa but i only have experience with it on an na6. it is just a fuel piggyback tho, it doesn't do timing or anything else.
not sure how the megasquirt works on a 99 nb either, i know there are issues with the nb engines that have the variable valve timing or whatever its called.... i don't know if your car is one of those.
in general i don't know much about nb's , sorry.
