I have an oil temp sensor which isnt connected, just sitting in the engine bay, near the right strut/intake manifold.
On a hot day (aircon needed), approx +26degrees
With headlight cover closed, engine bay temps were approx 65degs
With the headlight cover open, and it drops to about 40degs.
Summer's coming, open your \"eyes\" (NA models)
- Boags
Fatty wrote:see, your radiator cools your coolant because there is a pressure difference between the air on either side of the radiator. this pressure difference helps to suck (or push, not sure which ) the air through the radiator. by fitting a duct, or raising your headlights, i think you are actually reducing this pressure difference. SO , whilst your engine bay temps may improve, it is possible that your coolant temps may actually rise.
*WARNING: ANECDOTE FOLLOWING*
I have no *evidence* as such, but an anecdote... Just after I mounted my intercooler (before the turbo went in) I went on a club run on a very warm day through the Gold Coast Hinterland. With the lights down I was getting the temp gauge climbing, with the lights up the temp gauge would return to normal. This only tells us ONE thing:
Having the lights up lowers under-bonnet temps sufficiently to help the cooling system overall. It DOESN'T tell us that it helps or hinders airflow through the radiator.
Even with the turbo, if she gets warm I just pop the lights up.
I think I'm going to do a NACA duct when I get back from OS...
Boags
- Steampunk
Boags'MX5 wrote:I think I'm going to do a NACA duct when I get back from OS...![]()
Boags
Oh I am like SO there for that dodgy day
I'm just wondering where we'll place the jack this time round
i dont think its worth doing a writeup. Im 17 and it cost me $6 so i suppose anyone could do it. Just put a switch in the power to the motors. I found the wire that enters the fuse called \"retractor\" and extended it to the dash, put a switch on it and back to the fuse. Totaly adjustable and keeps the lights tilted foward so they are just 2 big scoops.
http://s213.photobucket.com/albums/cc50 ... CN0974.jpg
http://s213.photobucket.com/albums/cc50 ... CN0940.jpg
Overkill is an understatement.
well this has been very informative, thanks everyone. i have never had overheating problems on the road, even in 35+ weather. it's only ever been an issue on the track.
i guess the cheapest (free!) ,and maybe even the most effective, mod for me to do then, is just to remove the headlight cover alltogether at track days. it's only a few screws, afterall.
- green_comet
- Car Detailing Guru
