NA Diff
- corners
- Vehicle: ND - Supercharged
NA Diff
Hi all
I have an NA6 with standard diff. I am looking at upgrading to the NA8 diff.
I know what bits are required, my only question is, will my current LSD centre in the NA6 diff fit in the NA8 diff?
Jaron
Jaron
- StanTheMan
\"No\"
The NA8 diff center in a little smaller than the NA8/NB8
- Matty
- StanTheMan
well, you could always try to sell the NA6 LSD & diff. To recoups some of the cost. I'm sure there would be plenty of takers.
A full conversion would be around $1500-$2000 depending on where & how you get your bits together. Minus whatever you get for your bits.....
- Boyracer
- MX-5 Encyclopedia
If you can wait a few months I will be selling a 1.8 conversion with clutch type LSD fitted...it's a Kaas or Cusco something like that...not sure which one yet as it's still in the car...
Probably will be asking a bit under $2k for it.
- corners
Boyracer wrote:If you can wait a few months I will be selling a 1.8 conversion with clutch type LSD fitted...it's a Kaas or Cusco something like that...not sure which one yet as it's still in the car...
Excellent i'll be def keen
- timk
- StanTheMan
saboteur wrote:When you do the upgrade, if at all possible I would try and stay with the 4.3:1 ratio so the car doesn't lose acceleration, or it may take some of the fun out of the car.
Neva.......
- slammer
jcs86,
You can buy my disassembled Mazspeed LSD for $400 which will drop straight in to your car and keep the 4.31 ratio.
Or you can buy a 1.8 rear end with LSD and refit a Mazda Bravo or Ford Courier 4x4 front diff which is 4.4, figure 2K for the 1.8 bits $300 for the new ring and pinion and $500 to fit and install 4x4 ring and pinion. Do it all at the same time and you'll be up for around $2800 Do it one at a time and your up for 1K more.
Been there done that
- corners
slammer wrote:jcs86,
I was planning on getting a 1.8l rear end keeping the 4.3 ratio and putting a decent lsd centre in and then selling all the 1.6l bits
- timk
jcs86 wrote:I was planning on getting a 1.8l rear end keeping the 4.3 ratio and putting a decent lsd centre in and then selling all the 1.6l bits
I've got an 1800 diff/tailshaft/driveshafts with a TorSen II and 4.3:1 ring gear, it's brilliant, couldn't be happier. Give Richard at MX-5 Plus a call and he should be able to get you sorted.
- corners
saboteur wrote:jcs86 wrote:I was planning on getting a 1.8l rear end keeping the 4.3 ratio and putting a decent lsd centre in and then selling all the 1.6l bits
I have contacted him earlier. Just wanna get something with a decent lsd centre.
- Matty
my prices were:
1.8 open diff and shafts (installed by Dodgy Sab and Dodgy Andrew) - $500
Baba's Torsen - $600
wrecker 4.44 diff - $250
so $1350 in parts.
cost of never getting around to installing the diff:
