High flow metal cat
stevesports
High flow metal cat
Postby stevesports » Sat Feb 23, 2008 1:31 pm
Hey guys, did a search around this section and can't see this question being answered.
Does the NB8B benefit from having a high flow metal cat compared to stock?
if so, to what extent?
cheers.
Matty
Postby Matty » Sat Feb 23, 2008 3:58 pm
Probably not. Depends what else has been done to the car, but on a relatively stock one, probably bugger all difference
AB7
Postby AB7 » Sat Feb 23, 2008 4:18 pm
Unless you car is hi-powered turbo, then its not worth it. Just get hi flow cat, its around $120 rather then paying $300+ for Metal Cat.
Sheck
Postby Sheck » Sun Feb 24, 2008 12:40 am
I would say yes, if you belive an exhaust will give you more power (noticible) then you should replace the most restrictive part with a high flow item.
Get an x-force metal cat they are failry cheap, about the same price as what an exhaust shop will charge for a new stock cat..
stevesports
Postby stevesports » Sun Feb 24, 2008 11:34 am
hmm, where can i get a hi-flow cat for $120/
Sheck
Postby Sheck » Sun Feb 24, 2008 2:57 pm
I got mine from www.importautoparts.com.au not sure of exact price but its not too expensive. Alot of the shope i looked in charged more than 120 for a normal cat too.
Steampunk
Postby Steampunk » Sun Feb 24, 2008 7:15 pm
there's \"hi-flow\" cats and there's \"high-flow' cats.
If you want a proper one, trawl around various forums, ask reliable people and trusted shops, cause there are only a handful of catalytic convertors that are truly high-flow, or should I say more appropriately, less-restrictive.
As for power, the concensus is that a good complete system should produce more power, but the tangibility is in that the engine revs quicker and freer.
AB7
Postby AB7 » Sun Feb 24, 2008 7:29 pm
stevesports wrote:hmm, where can i get a hi-flow cat for $120/
I got it off ebay last time, its brand new too
stevesports
Postby stevesports » Sun Feb 24, 2008 7:38 pm
Hmmm, well i guess the next question regards the legality of a high-flowing metal cat converter.
Matty
Postby Matty » Mon Feb 25, 2008 4:41 pm
might as well just get an old commodore one from a wrecker. Good for ~150kW easy, cost bugger all.
Postby sliq » Wed Feb 27, 2008 3:12 pm
[quote="1red5"]there's "hi-flow" cats and there's "high-flow' cats.quote]
what's the difference between "hi" and "high" ?
how many kw's will you be looking to gain from a custom catalyzer? from the sounds of things, it's not worth spending $400 or so for a metal cat :?
Steampunk
Postby Steampunk » Wed Feb 27, 2008 4:40 pm
sliq wrote:
1red5 wrote:there's "hi-flow" cats and there's "high-flow' cats.quote]
:P spelling :P
What I am getting at is every man-and-his-dog will try and flog off so called "high-flow" cats, but not many genuinely flow faster, ie less restrictive, than OEM.
