Short Shifters
TieNN89
Short Shifters
Postby TieNN89 » Sun Feb 17, 2008 9:15 pm
Anyone here got a short shifter for an NB?
Where abouts did you get it and how much?
And what do you think of it?
And will it cause any damage? increase wear?
wun911
Postby wun911 » Sun Feb 17, 2008 10:07 pm
Will a 5 spd short shifter fit a 6spd car?
Have people here ever cut the stock shifter and tapped more thread?
every ounce counts
TieNN89
Postby TieNN89 » Sun Feb 17, 2008 10:16 pm
MX5parts is selling one http://www.mx5parts.co.uk/product_info. ... cts_id/556
Please note: The 6 speed lever will only fit cars prior to Chassis Number: NB18**214807 (approximately August '01). The 5 speed lever fits all models to date.
but it'd cost somewhere around $150-$200AU landed
pcmx5
Postby pcmx5 » Mon Feb 18, 2008 8:45 am
AZNTieN wrote:MX5parts is selling one http://www.mx5parts.co.uk/product_info. ... cts_id/556
I have a 10AE 6 speed in my car and bought a Simpson Design short shifter(about $180 landed).
Obviously there is a difference in later NB 6 speeds as Jim Simpson made it clear it was ONLY for an early 6speed.
It works well, makes the 6 speed feel much more precise.
6 speeders have two slots in the "ball" at the base of the lever,ie.two locating pins in the housing so a 5 speeder will fit a 6 speeder only if you make another slot.
Peter.
Steampunk
Postby Steampunk » Mon Feb 18, 2008 9:27 am
check out one of the group-buy threads.
If you want one, I can probably get you a good deal... around $70 posted .. maybe
Benny
Postby Benny » Mon Feb 18, 2008 3:10 pm
I have the IL one in my SP, fitted by Dave from Mania, and it is fantastic!
Driving a standard one now feels like I'm rowing a boat.
TieNN89
Postby TieNN89 » Tue Feb 19, 2008 9:12 pm
Steampunk
Postby Steampunk » Wed Feb 20, 2008 9:13 am
Yup. That's the one boags organised.
Mine was the same but from a different vendor.
No idea what the third picture (the shaft with the hole) supposed to be though as it's not part of the short shifter for the MX-5.
Patty
Postby Patty » Wed Feb 20, 2008 10:03 pm
1red5 GB
Do these only fit an NA? I read on miata.net that the manual gear lever is not compatible with an NB ka-chow!
I've got an NB8A, keen on getting an economic short shifter. :mrgreen:
Grace Green NB8A
TieNN89
Postby TieNN89 » Thu Feb 21, 2008 12:19 am
yeah do they have 2 slots in the ball
apparently na has only 1 slot
but when i took out my gearshift to replace the oil it had 2 pins and 2 slots on the stick
PASHN8
Postby PASHN8 » Mon Mar 03, 2008 11:51 pm
Does anyone make a short shifter for a NB8C SE 6-speed?
- 2005 MX-5 SE
http://www.dinography.com.au - From the ground
http://www.skysight.com.au - From the air
Steampunk
Postby Steampunk » Tue Mar 04, 2008 8:44 am
Peter.
The ones Boags and I organised are only designed for NA's. Haven't found any economic ones for NB's. It's ridiculous how much shops want for them. I've seen $200+!!
I've even seen one shop (that had a write up in the US Miata.net forum) that sells that standard shifter, but cut short, for $100.
PASHN8
Postby PASHN8 » Tue Mar 04, 2008 8:49 am
Only problem is a shifter that is 'cut short' reduces the height of the actual gear knob, but doesn't necessarily reduce the 'throw' between the gears :(
- 2005 MX-5 SE
Steampunk
Postby Steampunk » Tue Mar 04, 2008 9:26 am
that's what I mean!
What kind of a moron would pay good money for the exact same thing that he has standard, but cut a cm shorter AND doesn't work properly.
wun911
Postby wun911 » Tue Mar 04, 2008 10:45 am
LOL dam I was tempted to cut mine...
every ounce counts
