Heel toe vs heel toe double de clutch
- Steampunk
Im trying to learn heal and toe for nat meet. I think I need proper lessons (my mom taught me how to drive manual).
So all my life and for the last 4 years in the MX5 I have been doing this:
Slow down a bit
Aproach the corner
Put my foot into the clutch (foot remains in the clutch efectively in neutral)
Corner is finished
Put it into the gear I want
Take my foot off the clutch
And push the accel on
(effectively the whole corner is in neutral)
I think from the discription I was doing double de clutch without the rev matching when I had my leaky master and slave. It was kinda good because it forced me to never leave my foot in the clutch for more than a second.
Any advice/lessons for nubes wanting to learn H&T with super bad life long habits?
Slow down a bit
Aproach the corner
Corner is finished
every ounce counts
- fattima
Hi Wun,
Bit hard to explain it all here but what you are doing will not be quick on the track. Have a read of this
http://www.turnfast.com/tech_driving/dr ... ltoe.shtml
I also have a copy of SpeedSecrets by Ross Bentley worth a read if you would like to borrow it.
Bruce
Bruce
- Steampunk
wun911 wrote:So all my life and for the last 4 years in the MX5 I have been doing this:
Slow down a bit
Aproach the corner
Corner is finished
(effectively the whole corner is in neutral)![]()
If you were told to do that, then that person needs to be shot.
- Hot Rodders
wun911 wrote:Im trying to learn heal and toe for nat meet. I think I need proper lessons (my mom taught me how to drive manual).
Slow down a bit
Aproach the corner
Corner is finished
You should be in the correct gear before entering the corner and accelerate out of the corner. If clutch is in during corner, you basically have no control, If you come on the run Thursday night up Mt. Dandy, we'll give you some lessons.![]()
Wun, the golden rule is that when you start to turn into the corner you should be in the gear that you want to exit the corner in with your foot off the clutch. This means you can accelerate smoothly out of the corner. You don't use the clutch again until you need the next gear further along the road.
I'd recommend that you get that bit right first before moving on to heel/toe stuff.
- fattima
- timk
marcusus wrote:Just to be clear, this is what I'm doing, and what I consider as a heel toe double de clutch.
1 - foot on brake and held on for the remaining steps, with foot positioned over the accelerator ready for the blip.
2 - clutch in
3 - out of whatever gear I'm in
4 - clutch out
5 - blip accelerator pedal to appropriate revs
6 - clutch in
7 - in to the lower gear I want to change to
8 - clutch out
That's also what I do when I'm driving on the street.
I do it this way as well, and it feels much smoother than blipping with your foot on the clutch. This could be due to the fact that I still have the original 1989 gearbox and it's not too healthy?
- marcusus
OK, did some experimentation today. It wasn't as smooth as my version in terms of its rev matching, but it still worked. However, putting the car into the next gear felt identical to if I did it without doing the double clutch ie changing gears normally. There was no rev jolt, but there was still a bit of effort involved in putting the stick in.
So, based on this, I'm gonna stick to my method. The example is if I'm coming into the last turn at Wakefield in 4th and I do it the way the majority of you seem to do it, it'll require a bit more force to get the stick to go into 2nd. If I do it my way, it'll slot in nice and smooth, which gives me more time to be on the steering wheel.
I'll probably still practice both methods whilst on the street though. Never hurt to have another trick under your belt, and it might come in handy.
- Locutus
saboteur wrote:I do it this way as well, and it feels much smoother than blipping with your foot on the clutch. This could be due to the fact that I still have the original 1989 gearbox and it's not too healthy?
ditto.
when done correctly, changes are very quick and silky smooth - almost feels like there's nothing connected to the shifter.
also, the quicker the blip the more throttle you need. the more throttle, the more induction growl.
I am with you on this Marcus. I always ddc and it is now second nature. I cannot see how it takes longer in track circumstances because you are braking and not needing to put drive to the wheels. If you are braking enough to change down a gear you have time to ddc, it is only a matter of tenths of a second. It probably does not matter at track days but I have been told by at least two seasoned driving instructors that if you are running in an enduro event, cars like WRX's will start to lose gearboxes if the drivers do not ddc. It is definitely better for the gearbox and if you are skillful enough it will not effect your braking or cornering performance. JBT is right you do not need to ddc, as the required gears will engage because of the syncros, however it stresses the gearbox less if you do. I also find that you can actually feed the clutch out faster in some circumstances because there is less likelihood of unsettling the rear end when it is light on grip due to heavy braking.
If is it is better for your gearbox and can be achieved without lowering braking or cornering performance what is the problem??? Maybe I am just paranoid about having to change my gearbox
Sasso wrote:l
Its not that hard even on my old box but fiddling with the clutch made it better (although its gone worse again for some reason).
Maybe your syncros are rooted and you need to ddc
