Sasso wrote:I think Marcus is trying to get his post count up, so he can get to "speed racer" the easy way.
Pfft. If I was trying to get my post count up, you'd notice
Sasso wrote:Seriously though it works. You can downshift without the clutch at all, but you have to be good. If timed right the gear will go straight in as if the clutch was pressed. All you gotta do is when you are slowing down put force on the gear lever blip the throttle hard enough so that it rev matches perfectly, the gear will pop out and when the revs are matched the gear will pop into the next gear down, no clutch at all, that give the left foot nothing to do, so use it to brake! I employ you, try it. You will feel like a retard though, (and look like one when you stab the brakes with your left foot thinking you need to clutch).
I've done it once before in my old Ford laser. It wasn't easy, but it worked. Didn't use the clutch to get the gear out, and didn't use it to get it in. Did it once so I can say I've done it before, but sure as hell not doing it again. Too much precision involved and doubtful that it'll ever serve me well on the track.
Sasso wrote:To quote him a bit on braking and double clutching. The [] is me.
"A good shift (up or down) should be heard but not felt. It should also be fast - very fast.
[Talks about how rev matching badly (too high or low) snatches the rear tires, markus, its not ok to go slightly over like you keep saying, you have to be spot on, you don't really have time to wait for the revs to drop to let the clutch out if you over blip.]
Of course it's the ideal situation to have the revs exactly where the engine is going in terms of it's speed, but this all comes down to practice. It requires a lot more time on the track to know how much I need to rev the car to before it's a perfect match. On the street I'm a lot more precise, but there are still situations where I over rev purely because I haven't done the changes at those speeds before.
Sasso wrote:"Many authors (or maybe transplators) who should know better recommend double clutching in the racing car - I'll be damned if I know why. I do not know of one racing driver who double clutches - either up or down.
This all depends on who you know though
That quote is a little too subjective for my liking.
