RCA Cable route? PICS PAGE 3
ducktape69
Postby ducktape69 » Thu Mar 13, 2008 10:24 am
Hi all,
where's the best and easiest route to run the rca cables/remote turn on wire from the headunit to an amp in the boot?
Sam
BLECK 2002 Mazda MX5 NB8B. Custom Heatshielded CAI . KYB AGX's + King Springs. 17\" Bleck Rims. Custom BASSSS Install.
chatchat
Postby chatchat » Thu Mar 13, 2008 10:52 am
I run my cables on the passenger side, there is a hole behind the passenger seat can access to the boot, but might need some tool to pull the wire from that hole to the boot.
green_comet
Car Detailing Guru
Postby green_comet » Thu Mar 13, 2008 10:53 am
mine runs under the centre console, then under the rear firewall carpet behind the drivers seat, and into the boot via a hole that is in the firewall.
ducktape69
Postby ducktape69 » Thu Mar 13, 2008 11:03 am
sweet!
sounds like the centre console is the best option.
not too sure about the 'rear firewall carpet' routing... ? does the carpet easily come off?
Ajay
Postby Ajay » Thu Mar 13, 2008 12:28 pm
its just clipped on and, lift it up and the holes are there :)
PASHN8
Postby PASHN8 » Thu Mar 13, 2008 12:38 pm
Yep, passenger side here as well :)
- 2005 MX-5 SE
http://www.dinography.com.au - From the ground
http://www.skysight.com.au - From the air
ducktape69
Postby ducktape69 » Thu Mar 13, 2008 1:08 pm
thanks heaps guys.
sounds easy enough :)
Postby Okibi » Thu Mar 13, 2008 2:10 pm
green_comet wrote:mine runs under the centre console, then under the rear firewall carpet behind the drivers seat, and into the boot via a hole that is in the firewall.
Yup same here, if you're really slack you don't need to take off the center console and can just poke them up under one side :D
ducktape69
Postby ducktape69 » Thu Mar 13, 2008 2:59 pm
wouldnt it be better to run the cables on the passenger side as not to get close to the battery cables on the driver side boot?
is the hole in the passenger side firewall same as driver side firewall?
NMX516
Postby NMX516 » Thu Mar 13, 2008 7:06 pm
X2.
Get some decent shielded RCA's and you won't have a problem with sound from the car electrics anyway.
Russellb
RIP Nov 2014
Postby Russellb » Thu Mar 13, 2008 8:36 pm
NMX516 wrote:[
X2.
must get around to this on mine. the alernator nosie is NOT COOL :(
FYI mine is under the center Console and then around to the battery Area to the Amp.
My ClubmanRebuild
MX5 SE Rally car is HERE :)
Alex
Postby Alex » Thu Mar 13, 2008 9:18 pm
I wouldn't think all the wires would fit under the centre console
I took off the passenger side door sill then under the carpet there is a tube for running wires through, I just removed it and used the gap to run my own wires
ducktape69
Postby ducktape69 » Thu Mar 13, 2008 11:51 pm
bought some nice shielded RCA cables and remote wire cabling today...
will chuck it in saturday hopefully...
anyone have any experience if the hole in the firewall in passeneger side is easier or better to get through then driver side (and if battery 'noise' affects cabling on driver side)???
ducktape69
Postby ducktape69 » Fri Mar 14, 2008 9:12 am
any reason why most people using driver side rather than passenger side?
marcusus
Postby marcusus » Fri Mar 14, 2008 5:48 pm
My cabling is running to the passenger side. No detrimental effects there. Don't know why I did it that way rather than behind the driver's seat.
