whirring noise in gearbox
Any NB8B guys, can you try something for me?
can you find a quiet sort of place, go up to like 50-60km/h, get out of gear and into neutral, release and clutch and try to engage first gear. Now don't exactly try to get into gear, but apply a little force so the synchro is engaged. Tell me do you hear a whirring sort of sound, kind of like 2 straight cut gears are moving together?
i mean is this normal? are the synchros supposed to make that noise?
- Alex
- Uncle Arthur
- Dodgy Award Benefactor
- Location: Doesn't matter where I'm from-it's that your daughter is with me that's the biggest concern :D
Re: whirring noise in gearbox
stevesports wrote:Any NB8B guys, can you try something for me?
Sounds like you need a new hamster.
Let me explain it this way, there is a whining noise when i am in first gear and accelerating. It is less prominate as i move up the gears. Faint in 2nd gear, even less audible in 3rd and inaudible in 4th. In addition, the sound decreases as the gearbox warms up.
the reason i explained the above situation is to isolate the problem. As i said, i've narrowed the noise down to synchros (which i think is correct).
- bensale
One thing that can contribute to gearbox noise in the mx5 is the proximity of the gearbox to yourself.
I know my NA6 has a bit of gearbox noise, as does ever one i've been in so I would say its typical. I've never been in a nb so I cant on them.
I would recomend a back to back test, maybe take a mate down to a car yard with a nb and go for a test drive.
www.othersideproductions.com
