max boost for 10:1 motor
sprx3
Postby sprx3 » Mon Mar 17, 2008 2:31 pm
i found some very useful info when i was in the process of installing my emu (emanage ultimate) but thats all i really use the forum for.... lots of bullshit on there as well, you just have to keep out of the sh*t & you will be right
want to join the mazda car club of australia?, for more info please p.m me
Russellb
RIP Nov 2014
Postby Russellb » Mon Mar 17, 2008 8:57 pm
Well After the Rebuild the Engine came out at 9.9:1 comp
was after 10:1 but its close enough :)
got it in the car today and It started on the first turn of the Key ( after fixing the busterd injector ORING . Hope to have it on the Dyno on Wednesday night then off to Bathurst
Will post Dyno results when its done
Heres hoping for 200+ on 14 PSI :D
My ClubmanRebuild
MX5 SE Rally car is HERE :)
Russellb
RIP Nov 2014
Postby Russellb » Wed Mar 19, 2008 10:18 pm
Well the Engine made 190KW ATRW on 12.5 PSI of Boost.
ther was mopre init but the boost controler was having problrms over 13 PSI ..
Want to go to 20 but his will have to wait
My ClubmanRebuild
Russellb
RIP Nov 2014
Postby Russellb » Wed Mar 19, 2008 11:14 pm
drifter wrote:Nice tune 8)
20psi :shock:
With te New Hbeam Rods and Wiseco pistons It will take it. did a run with no actuator and the boost was stuiped we stoped a 20 psi @ 5000rpm and it was over 200KW so with control of boost 250 KW will be easy :) . now for cams and lift the Rev limit to 8500 RPM . might take a wile for that to happen as funds are low.
My ClubmanRebuild
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Thu Mar 20, 2008 9:41 am
brilliant - what did the build set you back?
Russellb
RIP Nov 2014
Postby Russellb » Mon Mar 24, 2008 9:17 pm
Pistons and rods from the states were just under $1000 landed
over sized vales $430 a set landed
valve springs $500
al aprox $$$$
Gaskets $390
everything else FREE :D
My ClubmanRebuild
16bit
Postby 16bit » Tue Mar 25, 2008 10:55 am
sweet so this kit should pretty much cover it all.
http://www.belfabracing.com/product_inf ... 7acf5bc994
what do you think labour would be for the non engine builder amoungst us?
