SE Cooling Issues?
AL
Vehicle: NA6 - Turbo
Postby AL » Thu Mar 27, 2008 10:06 pm
Craig, I think you'll find it's a normal thing wihth turbos. The higher head temps especially in summer can accumulate steam.Turning on the heater helps it to escape from the back of the head. Idling down after a hot run with the heater on should help. The \"wonky\" feel sounds like high intake temps common with the SE known as \"summerlag\". Oh,and if that all sounds like rubbish then it's probably just a head gasket :lol: Turbos aren't all tyre smoke and giggles you know.
Tinkered with 1991 NA6
SPy vs. SPy
Postby SPy vs. SPy » Thu Mar 27, 2008 11:20 pm
I think it is a \"quirk\" with every 10000 Mazda donks, mine has done it consistently for 5 years, No expert I have yet found can solve it, just confirm that \"yes it does gurgle for no apparent reason doesn't it . . . .\" it can do this after a 5 minute run to the post box and back from dead cold.
It's other trick is to empty the contents of the overflow bottle onto the floor, then cool down and suck the bottle completely dry.
New thermostats, countless radiator caps, and even the radiator has been pulled to bits.
Next plan of attack is an oil cooler, as the oil is used to cool the turbo, which then goes to a funny place called the engine.
Otherwise it's the cooling reroute trickery thing, probably both.
Postby Okibi » Thu Mar 27, 2008 11:30 pm
You could use one of those tanks to burp the cooling system. I think Mark did an autosalon article on them.
bigdog
King of the kennel
Postby bigdog » Thu Mar 27, 2008 11:47 pm
Okibi wrote:You could use one of those tanks to burp the cooling system. I think Mark did an autosalon article on them.
:mrgreen:
JBT
Postby JBT » Fri Mar 28, 2008 8:20 am
ASE05 was having coolant problems at NatMeet track day and then afterwards with huge changes in the overflow bottle levels. Played around with radiator cap and cleaned grunge off the rubber seal and it seemed to behave itself again on the road home to Brissy.
Suspect it may be the radiator cap - try a new one Craig.
Garry
Postby Garry » Fri Mar 28, 2008 8:34 am
My engine was making coffee percolator noises when I turned it off. I replaced the radiator cap and it stopped doing it. I couldn't hear the gurgling noises with the engine running though.
Daz
Postby Daz » Fri Mar 28, 2008 8:51 am
Mine has pretty much always done that, usually its a very slow gurgle, not like fluid boiling rapidly. I installed a real temp gauge to check the water temps, but they are very stable even under heavy runs and it seems it only does it when the car isnt running and I guess the coolant is sitting still in the hot engine. Who knows what the Mazda service dept are running in there though, its probably a cheap as possible weak mixture, I should probably run a stronger mix to increase the boiling temp.
Silver SP - PSS9, 1:10:58
Craig
Postby Craig » Fri Mar 28, 2008 12:07 pm
Will try the new thermostat and radiator cap tonight and see what happens, just glad to have full boost again...I sooooo love turbo's now! :lol: :twisted: :lol:
Craig
Postby Craig » Fri Mar 28, 2008 12:08 pm
:mrgreen:
* SLAP *
Craig
Postby Craig » Sat Mar 29, 2008 6:35 pm
Changed the radiator cap and it's sitting a mm or two lower on the temp gauge and driving fine, so that was probably just it I'm guessing! 8)
JBT
Postby JBT » Sat Mar 29, 2008 7:15 pm
Tolja :P
jules
Guitar Hero
Postby jules » Sat Mar 29, 2008 8:59 pm
See JBT is very knowledgeable about most things, even paint 8)
Jules
JBT
Postby JBT » Sat Mar 29, 2008 9:36 pm
Thank you Deeyoolian. :P
PASHN8
Postby PASHN8 » Sun Mar 30, 2008 12:43 am
I haven't experienced this problem Craig, although I have noticed a bit of summerlag I believe?
My new FMIC arrives next week, and I will be fitting up next weekend hopefully, so will see if the change in airflow affects things!
- 2005 MX-5 SE
http://www.dinography.com.au - From the ground
http://www.skysight.com.au - From the air
Craig
Postby Craig » Sun Mar 30, 2008 2:12 pm
PASHN8 wrote:I haven't experienced this problem Craig, although I have noticed a bit of summerlag I believe?
I'm semi experiencing the :shock: "Bogging" :shock: (awaits FFG's response) problem that the yanks whinge about, but that said it just feels like it needs some new leads and sparkplugs to me, and a good injector clean! :)
Let me know how you go with the new intercooler...been considering that myself! Which one did you get? :mrgreen:
