removing the aircon - NA6
hey guys,
i will getting the system de-gassed today and then removing it at some point.
i know a few others have done this , are there any hints or tips you can share? how do i get at the condenser in the front... do i need to take the radiator out? take the nose off ? any tips or help appreciated .
cheers
james
cheers
james
- randymx5
What have/are you guys doing with your air cons once removed?
Im after the 'u' shaped piping which goes fromm front of the radiator to behind it... any chance someone wants to sell me theirs?
I have a holein mine from where it rubbed against some other plumming (turbo)
R&ALL
RED 1990 MX5, AVO stage II, 148.5rwKw
well i'm planning to keep mine just in case i decide to refit it later. if i was to sell anything i would only sell it as a complete set. it doesn't make sense to part it out as that would devalue all the left over parts.
surely you can get a peice of pipe made up at an aircon specialist, or buy it from mazda / wreckers?
- ampz
- Vehicle: NA6 - Turbo
Hey Fatty,
When you remove the compresor bracket that bolts to the side of the block, it has a bolt going through the front of the engine too. This bolt also hold your oil pump and it will be too long once you remove the aircon bracket.
If you leave the bolt off, your pump will eventually leak all over the place (how do i know this?
) Find yourself the same bolt (12mm head from memory, but I've had 3 beers) about 15mm shorter and you should be sweet!
Huh?
- sabretooth
well it;s been inoperative for a while now ive just learnt to live without it. it was difficult at first but you get used to it. my car is not really a daily driver anymore so it's not too bad. if it was a daily driver i' think twice about removing it , and maybe take the time to get it operational again.
