Uncle Arthur wrote:I'm getting a bit of slippage at the top of the boost
Ah nuts! That sucks...
Boags'MX5 wrote:Uncle Arthur wrote:I'm getting a bit of slippage at the top of the boost
Ah nuts! That sucks...It only gets worse once it has started too.
Boags'MX5 wrote:I was thinking more about the story of you fitting it and the swearing that ensued...![]()
Boags
Uncle Arthur wrote:Boags'MX5 wrote:I was thinking more about the story of you fitting it and the swearing that ensued...![]()
Boags
I've been known to swear when I change my socks......
AJ wrote:Uncle Arthur wrote:Boags'MX5 wrote:I was thinking more about the story of you fitting it and the swearing that ensued...![]()
Boags
i've known you to swear in a text message
ASE05 wrote:$385 is only for the removal and refit and machining of flywheel. Still waiting on price for clutchI hope this is OK as the car is already at the shop and clutch removed, just waiting on Jim Berrys price for the replacement clutch. I hope I haven't been jammed in the bum here $$$ wise??
blackster wrote: Out of curiosity was the OEM clutch slipping?
