Oil & Filter Change
kenson
Postby kenson » Mon May 12, 2008 9:44 pm
Yep I do it from the top and use an oil filter wrench cap that bolts onto my torque wrench
Last time I did it I got frustrated and ended up with cuts all down my arm :cry:
Locutus
Postby Locutus » Tue May 13, 2008 1:09 am
manga_blue wrote:After 3 or 4 times of doing it from the top your left arm develops a permanent bend and it gets easier.
:lol:
took me ages to get my first filter off first time around but you learn quickly not to overtighten the buggers. now comes off with the left hand alone with relative ease. 8)
silvermiata
Postby silvermiata » Tue May 13, 2008 2:59 pm
i also take it off from the top just by hand...
Last time i have changed it with 90 dollar mobil1, i forgot to put the plastic gasket on the filter, and what happened when i start the engine? a pool of mobil 1 under my car.... :evil:
make sure you have the ruber gasket on the oil filter. :)
corners
Vehicle: ND - Supercharged
Postby corners » Tue May 13, 2008 6:26 pm
1red5 wrote:3 words:
oil filter wrench.
Believe it or not, there IS a reason why they made these things.
You're in Brisbane right? Or was that someone else with a similar forum-name :roll:
if you are in Brissie, then you are more than welcome to borrow mine.
Yeah
I am from brissy area
I tried to strap type ones and bought one that bolts onto the end of the filter but as it turns out it is too big
Steampunk
Postby Steampunk » Wed May 14, 2008 6:53 am
Dodgy Day down at Jules's place this Sunday :wink:
check the MX5events section. There is absolutely no better place to remove oil-filters than Jule's garage.
jules
Guitar Hero
Postby jules » Wed May 14, 2008 10:09 am
Your Dodgy host will even show you how it's done.
Jules
Steampunk
Postby Steampunk » Wed May 14, 2008 10:26 am
jules wrote:Your Dodgy host will even show you how it's done.
Jules
And then I'll show you how it's done right
jules
Guitar Hero
Postby jules » Wed May 14, 2008 2:23 pm
...and then I'll take it back out of his big mouth.
Jules
Users browsing this forum: Bing [Bot] and 10 guests
