Lightweight 15x7 rims?
rascal
Postby rascal » Tue May 20, 2008 10:50 am
Does anyone know where is the best place to get LIGHTWEIGHT 15x7 rims (6kg or less), without having to sell an arm and a leg?
I am after a wide offset for my track only car. Around +10 or similar.
I've called a zillion wheel places (incl mx5mania & NPower) and most only do +40 (+33 at best) and/or 15x6.5, and seem to think I should be happy with that...
The best prices I can get are from USA, (949racing, 18racing) which even with shipping work out cheaper than here, but I want to make sure they fit before purchasing and I obviously cant do that with american orders...
TIA
Rus
wun911
Postby wun911 » Tue May 20, 2008 12:46 pm
Are they for NB8B?
Are you after volks?
every ounce counts
rascal
Postby rascal » Tue May 20, 2008 12:54 pm
No, not for NB8B.
Volks would be nice, but from ringing around, they seem to fall into the arm & leg category... :(
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Tue May 20, 2008 1:15 pm
best wheels I can think of in that range are the below.
http://www.perfectrun.com.au/performanc ... TC105N.htm
this weds one is forged and comes in a great offset of +20
http://www.perfectrun.com.au/performanc ... nCRKai.htm
this one i don't think is forged but it looks the goods and is about half the price with +27 offset.
Postage for these would be around 300 dollars so you could get the work rims delivered for about 1200 in total and you will have nice japanese brand name rims.
if this offset is not suitable invest in some wheel spacers.
16bit
Postby 16bit » Tue May 20, 2008 1:18 pm
if you pm with your email I can send you a spreasheet of various wheels that fit and what the weight is - as for offset its not on there.
stevesports
Postby stevesports » Tue May 20, 2008 2:10 pm
Get the volk CE28N. Weighs in at 4.1KG for the 15x7. Uber lightweight!!!
rascal
Postby rascal » Tue May 20, 2008 2:10 pm
16bit, Thank you for the info.
I was kind of hoping to find a local Melb supplier, so I can test for fitment before spending my hard earned dollars.
I'm running big brakes, and not all 15s will fit (eg Simmons) so I need to ensure they do fit first, before I order them and get stuck with rims I cant use...
I do have bolt on spacers at the moment with the heavy +38s, but was hoping to get away from them as I've never been that excited by using them, and its 1kg per wheel extra I don't need, especially when I only have N/A 4 cyl power, every bit counts.
rascal
Postby rascal » Tue May 20, 2008 2:11 pm
Thanks stevesports, CE28N would be great however they are an arm and two legs.... :(
rascal
Postby rascal » Tue May 20, 2008 2:20 pm
16bit,
pm sent..
Matty
Postby Matty » Tue May 20, 2008 2:36 pm
good-win-racing.com
price quotes online can be worked out for shipping here, but I think you can talk to them and get some cheaper options on the shipping rates.
Enkei RP-F1 and Pro-Race 2 are my faves...
rascal
Postby rascal » Tue May 20, 2008 2:45 pm
Matty,
thanks for the reply.
Again its a US site, which means I cant test fit them first to see if they fit.
If I have to go US then I'll prob get 949racings 6UL rim. 5.9kg for a +10 rim (ideal offset for me) $950 landed on my door..
Their ITA spec rim is only 5.1kg but only comes in +25. I'd prefer the +10 even if I have to cop the extra .8kg.
stevesports
Postby stevesports » Tue May 20, 2008 4:10 pm
i would recommend looking through miata.net or clubroadster.net to see if other people have fitted those wheels. I think the guys there can advise if it will fit.
rascal
Postby rascal » Tue May 20, 2008 4:17 pm
Unfortunately I don't have a std (or common) brake setup so I need to fit the wheels to see if they will clear the calipers..
16bit
Postby 16bit » Tue May 20, 2008 4:30 pm
bloody hell they are well priced wheels. i would think that the extra weight would only add strength which is probably a good thing. I think I may have found my next set of wheels.
Benny
Postby Benny » Tue May 20, 2008 6:08 pm
I know they are in Sydney, but Tempe Tyres are now the importers of Lenso wheels, which are quite light and are now quite affordable.
They have a big range, and Sam from Tempe will also bring in special wheels for you at a very reasonable price.
Some years ago, I wanted to buy these particular wheels for my Mercedes, and the only place I could get them was from the USA at US$1200 a wheel including air freight.
Sam got them for me, in under a week, and all I paid was $1300 for the set of 4 including freight, fitting and balancing!
He even threw in a set of lock nuts.
