SE Intercooler - These OK???
- Craig
- Vehicle: Non MX-5
*** Audi Q5 55 Sportback - HYBRID! Zero -100 in 5.3 seconds!
- Boags
- Boags
I paid a little less than that for mine IIRC; around $120 posted...
Same size and quality by the looks of it. Keep your eyes peeled.
Boags'MX5 wrote:I paid a little less than that for mine IIRC; around $120 posted...![]()
yeah i think that was the justjap / cooling pro one that you bought. they have gone up , they about about $140 - $150 now i think.
- PASHN8
Too small Craigy!
THIS is what you want!
http://cgi.ebay.com.au/Front-Mount-Intercooler-560x180mmX65mm-Mini-INTEGRA-B16_W0QQitemZ180243893490QQihZ008QQcategoryZ130654QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
I bought from him and he was excellent to deal with!
- 2005 MX-5 SE
http://www.dinography.com.au - From the ground
http://www.skysight.com.au - From the air
- MINX
How much work to replace std SE cooler?
Will these fit straight in?
Do you need to remove front bumper?
Get new hoses/fittings?
What is the benefit for expense and labour (apart from appearance)?
- Boags
MINX wrote:How much work to replace std SE cooler?
Blackster (IIRC) did a good write up on replacing the standard cooler and the benifits of it.
It means you can have prolonged spirited driving (like a club run in QLD) without the intake temps getting too high. Great value for money IMO.
Boags
- ampz
- Vehicle: NA6 - Turbo
- blackster
Clicky here
Previous
04' MX5 SE.
02' MX5 Classic ed.
04' MX5 SE.
02' MX5 Classic ed.
- Boags
- Sean
- blackster
Sean wrote:Be wary of the ebay coolers mate, they are cheap for a reason. IIRC a few racers had temp problems worse than stock using these.
Nice for bling tho.
Are these the same racers who have machined holes in the bumper, running aftermarket radiator and IC, coolant re-route mod and oil coolers? If so, it sounds alot like a generic heating issue for over boosted tracked applications.
As far as the OEM SE interwarmer is concerned, its heat rejection and pressure is poor.
Is that size really needed? Is there an issue with pressure drop and lack of SA radiator exposure to air?
Previous
04' MX5 SE.
02' MX5 Classic ed.
04' MX5 SE.
02' MX5 Classic ed.
