Designing a locost style Lotus 7 Replica
Moderators: timk, Stu, -alex, zombie
Caffeine and others. I have just read an article in Australian Classic Car 9/07 #170 telling in words / pictures ( R McGown words) of Warwick Williams who built a Maserati 250F racing special- track car. He bought the Champion book and went from there. About the only thing the guy did not build was the radiator. Chassis aluminium body work Skyline engine with Dellorto carby's ( he removed the fuel injection) and from the photo's it is a thing of automotive beauty. Stunning what people are capable of doing and thru his skills and determination. Suggest try yr library ( thats where I get them) or of course go to ACC for back issue or subs. I have no connection with them. Ph 02 9319 4277 www.ccar.com.au
- Caffeine
Thanks Bigdog!!!! and Mrs Bigdog!!!!
Well, BJ & I went to see Bigdog's clubman, and sit around talking cars for a whole day, with a BBQ lunch, does it get much better than that?
The clubman is an awesome piece of gear, certainly inspirational and very interesting to see how it was put together... And the other race car, wow, that was awesome!
After much discussion, it seems an NC based, duratec 2.0L clubman with extended body (width, length & height wise) will be the way to go, and it looks like we'll be building more than one
- Caffeine
Blue94t wrote:Caffeine,
PM'ed you about a copy of the Cad drawings.
What's Bigdogs other race car? It looks a bit like an Elva in that pic.
Jake
A Buchanan
Great. NC running gear will make for a good clubby.
May I humbly suggest that you use the NC front suspension arms rather than following the \"book\" instructions. The factory arms will be stronger and maybe even lighter than fabricated arms.
I also suggest supporting the front pivot pins where the front arms meet the chassis, on both sides. The book method of just having a through bolt supported at one side is under-cooked and a poor detail.
Happy building! For many of us it is the building that provides the real pleasure. No speed cameras in the garage!!
M
M
- Caffeine
Mokesta wrote:Great. NC running gear will make for a good clubby.
May I humbly suggest that you use the NC front suspension arms rather than following the "book" instructions. The factory arms will be stronger and maybe even lighter than fabricated arms.
M
Excellent suggestions
We're thinking engine, electrics, gearbox, diff, suspension, axles, hubs and brakes
We'll also investigate using the PPF as well.
Interior wise, I like the look of the Recaro Profi seat, wonder if a couple will fit. Depends on the condition of the NC seats I guess...
- orx626
- Vehicle: NC - Rotary
Caffeine wrote:Depends on the condition of the NC seats I guess...
Caff, how about these two to get the project going?
http://www.aus-cartalk.com/viewtopic.php?t=29767&highlight=
Drop me a line when you want NC running gear.
- Caffeine
orx626 wrote:
Drop me a line when you want NC running gear.![]()
I gather you have the engine / gearbox & diff, what else do you have??
- Vehicle: ND - 2
Hopefully 2 of each of everything ;-P
BJ
Playing with BOOST will smoke your tyres!!!
NO LONGER MINE sob sob
- Vehicle: ND - 2
Caffeine wrote:Thanks Bigdog!!!! and Mrs Bigdog!!!!![]()
I second all of the above...Fantastic day, fantastic company ..Awesome all round garage will be finished soon , then off to buy some gear ;-)
BJ
- orx626
- bigdog
- King of the kennel
- Caffeine
Just about everything! Let me know what you need.![]()
Awesome
BJ, finish your shed!!!
- Caffeine
Started rebuilding the SolidWorks model of the car, based on discussions and ideas for impreovements we had with Bigdog on the weekend.
Now that we've decided to go with an NC as the donor car I'll be adding a simple, visually approximate but dimensionally accurate model of the NC drivetrain and suspension to the solidworks assembly, and adjusting the chassis to suit the NC hardpoints (i.e. engine / gearbox / diff mounts, suspension pick up points etc)
Has anyone got an NC they don't mind me disassembling to measure stuff?
what fun this is!
what fun this is!
Return to “Engine swaps, Exocet, Locost & MX-5 kit cars”
