bleed order
- 16bit
bleed order
just wondering what the bleeding order is for an nb8a. thanks!
- Woo
- Vehicle: 10AE - Turbo
Swap the Left and Rights in the above descriptions accounting for ABS on the '00 (four wheel ABS)
Swap the Front Left and Front Right on the '99 with ABS (3 wheel ABS)
Edit* The key is as JBT says start with the longest line (from the ABS pump or Master cylinder)
Very slightly modified 10AE #2562 ..... one of 149 in Australia
Race what you brung ..... And hope you brung enough
