Aftermarket Exhaust
TieNN89
Postby TieNN89 » Thu Jul 10, 2008 7:03 pm
Thanks AJ
I heard good things about them too which is why they were the first for me to call
Apparently they've done a few MX-5 lately
Oh BTW I'm not getting paid out 2k I have up to 2k for an exhaust which the insurance will pay direct
Postby manga_blue » Thu Jul 10, 2008 7:47 pm
Loch Stewart (aka Garry) do a full system of headers, hi-flow cat and the rest which are proven performers on naturally aspirated NAs and NBs. They are a well known set-up. Cost should be a lot less than $2k.
Even if you don't eventually buy from him it's worth at least sounding him out first. Contacts details Brisbanites?
TieNN89
Postby TieNN89 » Thu Jul 10, 2008 8:46 pm
Has anyone used Midas? the one at Woodridge on Kingston Rd
My MX-5 is going there for suspension work and they do exhausts etc
Steampunk
Postby Steampunk » Thu Jul 10, 2008 9:03 pm
I don't know Gary Stewarts' number (I thought I had it), but Novice1 (Ron) does, send him a PM.
The \"Loch Stewart\" headers are made by CES Racing by the way, down Beenleigh way. From what I gather, custom exhausts don't get much better, so if you can use up to $2000 may as well go there. I would.
TieNN89
Postby TieNN89 » Thu Jul 10, 2008 10:22 pm
1red5 wrote:I don't know Gary Stewarts' number (I thought I had it), but Novice1 (Ron) does, send him a PM.
does he own a performance shop or something?
PM sent to Novice1
RG.net
Postby RG.net » Thu Jul 10, 2008 10:55 pm
i would say buy mine (naturally) but if the insurance company is willing to pay out 2g then get 2.5 inch piping, high flow cat, 4-1 extractors and a nice tip. oh and to get as close to 2g make it stainless steal :D
TieNN89
Postby TieNN89 » Thu Jul 10, 2008 11:06 pm
mmm
whats the difference to what ever they normally use to stainless steal?
blehbear
Postby blehbear » Fri Jul 11, 2008 12:40 am
Wouldn't a 4-2-1 header system be better for the mx5s as it helps improve torque throughout the whole rev range?
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Fri Jul 11, 2008 10:57 am
i have the loch system. It gave me 87rwkw with a k and n typhoon intake. the headers are manufactured by ces and they are fitted by rob bliss exhausts.
stevesports
Postby stevesports » Fri Jul 11, 2008 11:11 am
AZNTieN wrote:
stevesports wrote:re: Cat, make sure it is a high flowing one. Also i would recommend you spend a little more on your headers for a high quality one. They are very important. Overall sounds like an OK price.
The guy said a high flow one isn't really worth it since mines just N/A 1.8L so he said the bigger cat would work
Headers they custom make it so I'm not sure how to figure out whats high quality and whats not
usually the bends and quality of the welds. IIRC you would want equal length pipes from the engine to the cat. also i would recommend 4-2-1 to maintain torque, however i believe a 4-1 system would be great for outright power. I prefer a beefy torque curve but that's just me.
re: stainless steel. It is more durable than mild steel. In addition, a stainless steel system would sound different compared to mild steel. A bit more raspy.
Steampunk
Postby Steampunk » Fri Jul 11, 2008 11:32 am
AZNTieN wrote:mmm
:roll: Pardon?
If you mean, what else are exhausts made out of besides stainless, then short answer is mild-steel.
Difference is, obviously, longevity; other difference is sound. Given 2 identical exhausts, stainless will make a high-pitched/tinnie sound, mild will give a deeper/droning sound.
Postby manga_blue » Fri Jul 11, 2008 12:47 pm
... or you can combine the two for the best of both.
The need for stainless increases towards the back where things are not as hot and there's more risk of moisture condensing there and rusting it out from the inside. So a stainless muffler and tailpipe are good.
Rust is rarely an issue up front, so that's a good area to use mild steel for low cost and better, deeper sopund.
4-2-1 headers usually gives a wider spread of power. 4-1 usually give more up top. But the variations in performance from design and manufacture quality are much, much greater than the 4-2-1 vs 4-1 issues.
The best advice is to go for one with a known MX5 pedigree.
Postby sliq » Fri Jul 11, 2008 1:28 pm
manga_blue wrote:... or you can combine the two for the best of both.
on that note, i'd stick with racing beat or similar brands when it comes down to headers.. for the power increase, imo the $$$ spent on headers aint worth the power gain..
Postby manga_blue » Fri Jul 11, 2008 1:59 pm
More like ... the power gain depends on the quality and matching of intakes, headers and exhausts as a set.
Steampunk
Postby Steampunk » Fri Jul 11, 2008 2:09 pm
This is what I read from respected/reliable/expert sources; unless you want to go for the fooly sick bling, then mild steel is better for exhaust manifold/headers than stainless due to the thermal expansion characteristics of the two types of steel. Mild steel expands and contracts less than stainless and therefore is less susceptible to stress and breakage.
