Can you advance timing with chipped ECU?
mr_rotary
Postby mr_rotary » Sun Jul 13, 2008 4:10 pm
I am going to have my mechanic pit in a new clutch in my NA6 tomorrow and at the same time ask him to advance the timing. I have since got hold of a Mines VX ECU and have not yet installed this. Basically it's a chipped ECU, plug and play which basically does the following:
1. Eliminate 180km top speed limiter
2. Shift rev limiter timing
3. Eliminate boost limiter
4. Modification of fuel correction map and Ignition map
5. Change quorum (k)
6. Change lattice of the map (RPM, injection time)
7. Modify every correction points
So, is it ok to advance the timing to 14° and plug this in withought doing any damage? If not, can the timing be still advanced?
Postby Okibi » Sun Jul 13, 2008 9:51 pm
That's easy to do with the stock dash.
Rotary
Postby Rotary » Tue Jul 15, 2008 8:31 pm
You really need to get directions from the programmer.
Theres no way of knowing unless its supplied with or you can get your hands on an ignition curve.
safest way if you can't get directions is set to 10Deg then install chip, because if they have advanced the curve it will be compounded by your advance.
They may reccomend setting the base timing to a value they have designed to work with their curve, but if so it would be set after install, not before.
These are only a few examples of the many possible variables, because only the programmer knows how thier own chip is programmed
Hope this helps, Let us know if you get more info on its setup
Matt.
Adam_NAclubman
Postby Adam_NAclubman » Tue Jul 15, 2008 10:15 pm
It will most likely be optimised for fuel thats better than what we get here. That + advanced timing could = BANG
mr_rotary
Postby mr_rotary » Wed Jul 16, 2008 9:18 am
Cheers for the info guy's.
Jimmy
Postby Jimmy » Wed Jul 16, 2008 9:29 am
I wasn't aware that the NA6 had a speed limiter. My old red one certainly didn't (got that to 185km/hr then chickened out) and neither did my mates (below)
Postby Okibi » Wed Jul 16, 2008 9:43 am
There's a screw in the back of the gauge cluster, I can't remember if you need to put a screw in or take it out to remove the speed limiter.
It says \"180\" next to the hole as far as I can remember. I have pics somewhere.
Postby bruce » Wed Jul 16, 2008 11:17 am
Only the japanese grey imports have a 180 limiter.
