Convert power to non-power steering
I heard this can be carried out on an NA. Can somebody confirm this? Apparently there is a bracket with an adjustable pulley that you can buy from the States, but I can't figure out how something like this can convert your car. i would have thought the power and non power steering system has different racks, etc. Would the feel be different than say a Clubman once converted? Is this part available here? Cheers!
NC sold, but will return one day.......
- Alf
Re: Convert power to non-power steering
This from miata.net http://www.miata.net/garage/pwr_to_manual.html
Looks like you need a manual rack.
Alf
Alf
- Steampunk
stupid comment time; (and yes, I read the article in Alf's link)
is it not just a matter of simply buying a different size (shorter) belt to join the AC compressor and crank pulley together? eliminating power to the PS pump?
So maybe it is not a matter of bypassing the ps pump, you need to replace the rack. I'm sure the two racks are different, hence why.
I've not come across anyone who had done it here, but I wondered if it was easy mod. I personally wouldn't.
- JBT
The racks are different. The manual rack is lower ratio - more turns lock to lock.
But whyyyyyyyyyyyyyyyyy
as jbt said the power rack has a higher ratio. apparently a lot of the racers in the usa put the power racks in their cars sans pump etc , or if already fitted, they de-power it by removing all the unnecasary bits. fine in a a race car but for a daily driver the steering would be a bit heavier. probably not unmanageable tho, if you're really keen on the whole "adding lightness" thing.
i ran a de-powered power steering rack. I loved it, the power steering was wayyy to light for me. My house mate that usually drives an excel seemed fine with it, only problems may be present at car parking speeds (not the speed you travel through the car park but, at which you park).
I didnt do it 100% properly more like 80%, i cut all the power steer lines at/close to the threads and 'pumped' out all the fluid that would be pumped out, then tried my best to put grease in there managed to get a descent amount in then 'pumed' it out again by turning the steering hard, lock to lock, with the front wheels in the air. A little of the grease came out and hey presto you've depowered your rack.
Weight removed wasn't much, so that thought would be for the die hards, more 'feel' in the steering well maybe but thats been talked to death. I did it cause i didnt like the lightness of the power steering, plus i think the seals were going because at times it seemed like i was pushing the fluid through the pump and rack which was very hard.
Dave
Dave
cool sheck ... yeah i thought i remembered someone around here had mentioned previously that they'd done it. from what you're describing, doesn't sound to hard to live with at all. my first car was a HQ kingswood wagon with heavy mag wheels and fat rubber. the manual steering on that beast was very heavy , i managed it ok so i reckon i could live with what you're describing...
Thanks guys, you have enlightened me!
Kula did a step-by-step pictorial tutorial in a recent Autosalon magazine. I've got the mag at home but have no clue with scanners.
- Matty
- GS
1989 NA6
- irwin83r
sweet.
when i get the garage back i might give this one a wurl
I wouldnt be too worried about "heavier" steering.!!! I just bought an Na with manual steering 2.8 turns lock to lock after having dríven TR2s & 3As all my life. Light as a feather compared to the worm and peg TR!! I dont like the 2.8 turns- Im used to 2 1/4 turns lock to lock so I might convert a power steering to a manual if that reduces the turns lock to lock.
O6 Marble white NC ;91 Malibu Gold NA 1800 BP4W;1990 BRG LE hardtop, unmolested, original; 1993 Brilliant Black hardtop, unmolested, restored.
Users browsing this forum: No registered users and 18 guests
