NA6 stub axles 24 spline 25mm od???????
flycasta
Postby flycasta » Mon Sep 15, 2008 8:38 pm
As the subject says, Can someone please confirm if the NA6 stub axle is 24 spline and approx 25mm od.
I have tried to buy a pair but nobody can help, hopefully someone can answer this question for me.
Thanks
Steampunk
Postby Steampunk » Mon Sep 15, 2008 9:02 pm
I just measured and counted my NA8 one, and if its the same as NA6:
- outside diameter NOT including spline = 23.5mm
- outside diameter from top edge of spline to top edge of spline = 26mm
- number of splines = 26
flycasta
Postby flycasta » Mon Sep 15, 2008 11:18 pm
1red5 wrote:I just measured and counted my NA8 one, and if its the same as NA6:
Thankyou for that...... The NA8 should be 26 spline and around 27mm od and the NA6 is different otherwise the stub axles from the NA6 would fit the NA8 and NB8.
It is the NA6 I am really looking for the info from.
Thanks for checking and getting back to me.
Duane
StanTheMan
Postby StanTheMan » Mon Sep 15, 2008 11:28 pm
