Injectors and pump with turbo kit
Adam_NAclubman
Postby Adam_NAclubman » Tue Sep 16, 2008 7:52 pm
My AVO kit came with a fifth injector, and supposedly will work fine with a stock pump, but I want to run four larger than stock injectors and a bigger fuel pump just to have a bit of extra peace-of-mind.
What brand/size injectors and pumps have you guys used?
SuperMazdaKart
Postby SuperMazdaKart » Tue Sep 16, 2008 7:58 pm
boyrcr has famila gtr injectors in his. gtx/gtr/tx3 turbo/rx7 injectors i believe should all be usable.
& no, you can't have my gtr injectors or my walbro high flow fuel pump.
Fatty
Postby Fatty » Tue Sep 16, 2008 8:04 pm
upgrading the pump is not necessary in many (most?) applications. i use 460cc rx7 injectors with the stock pump and it delivers more than enough fuel pressure for my needs. iirc there is a relationship between injector size and fuel pressure, upgrading one or the other is often all that is needed, you usually only need to upgrade both for really high power applications. there was some good info about this on miataturbo iirc.
but anyway, the walbro seems to be the pump of choice if you want to upgrade, or the pierburg. but those with first hand experience are probably better suited to give advice in this regard.
Juffa
Postby Juffa » Tue Sep 16, 2008 9:32 pm
I'm running the standard fuel pump, with 330cc high impedance injectors and 9 pounds of boost. I have a wideband O2 sensor and gauge so I can see the AFR at all times and to make sure I'm not leaning out or running too rich. If anything I am running too rich especially at the high levels of boost
Does the AVO kit come with some way of controlling the fuel, ie piggy back or replacement ECU?
I would suggest having a look at the FAQ section of miataturbo.net Heaps to read and understand.
http://www.miataturbo.net/forum/showthread.php?t=10821
J
Blue94t
Postby Blue94t » Tue Sep 16, 2008 11:15 pm
My car had 370cc injectors and I went to a higher capacity Walbro in tank pump.
Had no issues at all with that at 160rwkw.
I have to say that I am not a fan of 5th injector setups. If you can afford/justify the extra expense a stand alone ecu will give you much better results. I may have my EMS dualsport for sale soon with a loom to suit a 1.8. Happy to leave the map in it.
Jake
mx52nv
Purple Porsche Eater
Postby mx52nv » Wed Sep 17, 2008 1:29 am
Adam_NAclubman wrote:My AVO kit came with a fifth injector, and supposedly will work fine with a stock pump, but I want to run four larger than stock injectors and a bigger fuel pump just to have a bit of extra peace-of-mind.
Yes I agree with this completely as I did the exact same thing (started with a 5th injector way back in 1999).
Adam_NAclubman wrote:What brand/size injectors and pumps have you guys used?
I use 550cc RX7 Turbo injectors (aka "purpletops"), a Bosch 044 external fuel pump and a custom surge tank. Good for over 300rwhp and sprint/hill climb use.
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Wed Sep 17, 2008 8:52 am
i would avoid rx7 injectors for a piston car. every tuner I have spoken to says they have a very messy spray pattern. if you want a good upgrade injector i would get something like the familar gtr injectors or even some supra 7mgte 430cc injectors. you can get oem quality brand spankers from the states for around 60 bucks usd each.
[HTML]Year Make/Model Engine Size/Color Part #
87-88 Toyota MR2 4AGE NA 213cc – Beige Top #23250-16080
89-91 B2220 Truck 224cc - Yellow Top? #23250-74040?
99-00 Mazda Miata 240cc - Thin Red Body #195500-4430
Toyota 4AGE 250cc – Green Top
Toyota 4AGE 250cc – Violet Top
94-97 Mazda Miata 254cc - Tan Top #195500-2180
01-05 Mazda Miata NA & TURBO 265cc - Thin Lt. Prple #195500-4060
Toyota 3SGE 295cc – Green Top
89-92 Toyota Supra 7MGE NA 305cc – Light Green Top #23250-70080
93-95 Toyota Supra 3.0L 312cc - Maroon Top #23250-46030
Toyota 3SGE 315cc – Pink Top
90-92 MX6/626/Probe Turbo 326cc - Gray Top #195500-2150
89-91 B2600 Truck 326cc - Gray Top #195500-2150
Mazda 323 GTX TURBO 360cc - Black Top #195500-2130
Celica/MR2 3SGE NA 370cc - Green Top #23250-74160
Mazda RX8 420cc - Yellow Body #195500-4450
Subaru WRX 425cc - Lt. Blue Body #3920
89-92 Toyota Supra 7MGE TURBO 430cc – Black Top
89-92 Mazda RX-7 NA 440cc - Blue Top #195500-5740
89-91 RX-7 NA 460cc - Red Top #195500-2010
Subaru STi 540cc - Thin Pink Body #3910
89-91 RX-7 TURBO 550cc - purple top #195500-2020
Garry
Postby Garry » Wed Sep 17, 2008 10:03 am
My Walbro pump is extremely friggen noisey.
Adam_NAclubman
Postby Adam_NAclubman » Wed Sep 17, 2008 12:47 pm
The kit came with this sub-computer but I think I'd rather get an Adaptec or something... I was looking at going for a MegaSquirt but I was told their resolution isnt so great?
Postby 93_Clubman » Wed Sep 17, 2008 11:04 pm
Adam, just for reference, TDR includes a Walbro 255 LPH 130 PSI fuel pump in their boost upgrade kit for the JR M45 SC.
Garry, not sure if you know, or already have one, but you can get a heavy duty rubber sleeve for your Walbro fuel pump to quieten it down (see below).
http://www.trackdogracing.com/website/s ... l_pump.htm
zoomzoom
Vehicle: NA6 - Turbo
Postby zoomzoom » Thu Sep 18, 2008 3:14 pm
16bit wrote:i would avoid rx7 injectors for a piston car. every tuner I have spoken to says they have a very messy spray pattern. if you want a good upgrade injector i would get something like the familar gtr injectors or even some supra 7mgte 430cc injectors. you can get oem quality brand spankers from the states for around 60 bucks usd each.
Dunno what they are talking about there considering they are all the same type of injector, only difference is the flow rate.
Tim
PASHN8
Postby PASHN8 » Fri Sep 19, 2008 1:38 am
Tim
I think what he means is that they have been reported to have a different spray pattern which affects the atomisation and combustion process, I don't know how much of this is true however as I haven't seen the spray pattern for a rotary engined injector vs a piston engine. Would make sense though given the different shape of combustion chamber?
- 2005 MX-5 SE
http://www.dinography.com.au - From the ground
http://www.skysight.com.au - From the air
zoomzoom
Postby zoomzoom » Fri Sep 19, 2008 9:26 am
Tim
They have the same pintle type tip. The only issue I have heard is that you need to get them flow tested properly as 2 of them do tend to get quite hot on the rotary, and this had been said to affect the operation of the injector.
When I got mine I had them flowed one of them was flowing more than the others which meant it was stuffed, so I got onto the seller I got them from and had him send me another.
Garry
Postby Garry » Fri Sep 19, 2008 9:42 am
93_Clubman wrote:Adam, just for reference, TDR includes a Walbro 255 LPH 130 PSI fuel pump in their boost upgrade kit for the JR M45 SC.
Thanks for the info 93_Clubman. I have already wrapped it up in a rubber product and it's helped things a bit. But it seems to be getting noisier again. Maybe my pump is dieing.
randymx5
Postby randymx5 » Fri Sep 19, 2008 10:36 am
My injectors are from a 200sx.. pump is standard though..
one day ill get around to upgrading
R&ALL
RED 1990 MX5, AVO stage II, 148.5rwKw
