1JZ supra engine into a NB8B
Hi All,
As the title suggest an opportunity has risen and a mate can sell me his 1JZ engine with MX5 conversion kit ... still waiting on costs but is it worth it.
Would like to hear everyones 2c worth
Cheers Paul
Cheers Paul
90 NA6 98RWKW of fury 1.7L fury box
- 16bit
no - iron block will ruin it. you are better off buying an LS2 conversion kit from FM in the states.
or a rotary conversion, keep it mazda man!
hell yea go the 1J!!!! They are only a few, tens of, pound heavier than an SR20, from what i've heard about ppl tossing up the RB or 1J conversion into a silvia.
1J will make a sh*t load of power on the stock bottom end, though a LS would be nice you actually have the opportunity to do the 1J so its more realistic and i reckon it'd be awesome!!
- ampz
- Vehicle: NA6 - Turbo
Make sure you do your research first, then if you are still keen I reckon go for it.
Would be a great fun car, and an animal with the right turbo setup on it. And one other thing, take your cost estimates for the conversion and double it, maybe even triple it. When engine conversions happen costs have a habit of running away a bit. They are a great challenge though, and very rewarding when finished.
Jake
Jake
- PASHN8
Is this Chuck's setup?
- 2005 MX-5 SE
http://www.dinography.com.au - From the ground
http://www.skysight.com.au - From the air
Nark,
I have done a few engine conversions myself and have always found them rewarding. Especially when you go for the first drive.
Jake
Jake
Basically, I don't think you would be able to get it legally registered as;
-Engine capacity (2.5 and a turbo)
-Age of motor (it is older than the body)
-you're in NSW which is very strict with Engineering.
If that's true, that means you have to go down the track of an emissions test which is complicated and expensive.
Thanks all for your 2c worth and more!
Even though it may be boring might just go for an insane NA beast.
oh btw its not Chucks old setup its somebody else's.
Just for the sake of procrastination now whats the rarest setup people have seen in 5's?
Cheers Paul
Cheers Paul
Saw a picture of an RB26 in an NA (Japan).
20B in the Qld NA Bullet copy (related 2JZ NA as well).
mmm 20b MX-5
As well as the weight issue, you want to make sure the gear box still uses the power plant frame.
It's an important consideration a lot of engine conversions ignore.
I'm still (after all of the negativity from some people around) planning to put a Honda C32A (175kw, 295nm ALL ALLOY 3.2 litre V6) into an NA (no plans to register it)
C32B would be even sweeter, is there room to put the C32A east west under the MX bonnet?
