autoexe VS maximworks ... one and the same?
RG.net
Postby RG.net » Fri Sep 19, 2008 2:46 pm
sliq wrote:why do you want to change your headers oongie? the factory nb8b headers is said to be already well developed. unless you are chasing every single ounce of kilowatt from your car..
also note the difference between the maximworks 4-2-1 and RB 4-1. it's been documented on here the difference in range.
Racing beat designed their 4-1 headers to have the same low down-mid range as their previous 4-2-1 header, but it has more top end, as most 4-1's do, but most loose some low end. this is not the case with the RB headers.
Postby sliq » Fri Sep 19, 2008 3:05 pm
have got another chip to run the headers mxhevn? i hear some cars "fart" with headers with the factory ecu.
RG.net
Postby RG.net » Fri Sep 19, 2008 7:51 pm
sliq wrote:have got another chip to run the headers mxhevn? i hear some cars "fart" with headers with the factory ecu.
i have lots install check mygarage section and you'll understand :D
