Loud SSSHHHH sound on gear shift
white1.8
Postby white1.8 » Fri Oct 10, 2008 4:50 pm
Hi
Ever since i got my car this has been happening, when i rev up close to redline then shift there is a loud sound much like a blow off valve and i have no idea why this is happening or if it could be detrimental if anyone has any ideas what this is i would much appreciate it. My car is a naturally aspirated 94 model with exhaust and a pod filter thats the only things that were different to stock when i got it, it also happens when the air con i on or off
Cheers Matt
Boags
Postby Boags » Fri Oct 10, 2008 4:55 pm
My guess was going to be air-con. :mrgreen: My car sounds like that with the a/c on.
No idea other than that. Didn't get a turbo by accident did you? :twisted:
Steampunk
Postby Steampunk » Fri Oct 10, 2008 4:58 pm
a leak in the idle bypass system?
Log a run and see what MegaLogviewer say.
Come out for a run tonight and we'll check it out. See the "MX5 events" section.
Postby Okibi » Sat Oct 11, 2008 3:14 am
A leak in the EGR ? :?:
@ndrew
Postby @ndrew » Sat Oct 11, 2008 10:31 am
Congrat's you've bought a turbo car :lol:
Caffeine
Postby Caffeine » Mon Oct 13, 2008 11:59 am
Worn synchros?
white1.8
Postby white1.8 » Mon Oct 13, 2008 4:05 pm
I wish it were a turbo, I've wrapped the exhaust from headers back to the diff and sadly no turbo,
I was under the impression that there was no EGR on the aus models.
I’m pretty sure its engine rather than gearbox, I think the intake pipe thing is loose on the throttle, it could have something to do with that, there is a hissing sound coming from there and it stops when I apply pressure to it.
Now there is a loud clicking sound coming from the top of the engine (so I haven’t had chance to test anything else like revving when not in gear). The clicking it didn’t happen on the way there but did on the way home about half hr later, the timing belt is due from replacement, is this a typical thing or has something drastic happened?
Thanks for all the help so far
Cheers Matt
Steampunk
Postby Steampunk » Mon Oct 13, 2008 7:34 pm
so was I right?, or was I right? :P
white1.8
Postby white1.8 » Tue Oct 14, 2008 7:20 am
Its looking very much like you were right, ill check by using my arc intake thats got silicone conectors and hose clamps and see if it still happenes.
Still dont know what this clicking issue is though
Tezzax5
Postby Tezzax5 » Tue Oct 14, 2008 10:36 am
How old are your plugs & leads?
Hairline cracks in the ceramic part of the plug can lead to shorting out of the plug.....clicking sound from top of the engine.
I had the exact same sound....plugs and leads fixed mine...Hopefully yours will be an easy fix as well.... 8)
white1.8
Postby white1.8 » Thu Oct 16, 2008 1:54 pm
I unplugged them and had a look then re plugged them in and now theres no ticking, so it must have been a loose conection, i also checked my timing and it was out by about 2 degrees
white1.8
Postby white1.8 » Thu Oct 23, 2008 8:22 am
I fitted my ARC intake with the silicone adapter things and now the ssshhh sound is even louder :shock:
the start bypas thing (i think) is very firmly fitted even though there is no hose clamps, and the ventalation hose is attached with hose clamps, ill try revving in neutral and then closing the throttle and see if that still makes the noise.
white1.8
Postby white1.8 » Thu Oct 23, 2008 11:04 pm
:shock: :cry: i hope not, its been happening for 10 months, looks like ill be spending some money on maintainance soon.
nick viner
Postby nick viner » Fri Nov 07, 2008 9:27 pm
What is an EGR?
mx52nv
Purple Porsche Eater
Postby mx52nv » Sat Nov 08, 2008 1:47 am
nick viner wrote:What is an EGR?
Exhaust Gas Return
Memory fails me as to when this was first implemented in MX5s but I think it started in the first NB8s ... can anyone please confirm this?
