Has anyone used the tomei limited slip diff centres?
Just curious... found some cheap (well used to be when our dollar was up against the greenback).
Wanted to know how they stack up against the usual suspects Kaaz, std torsen etc..
Tomei lsds
- colster3
Tomei lsds
"yes yes yes! I know what I'm doing! Just leave me alone...
Tomei lsds
we reviewed one in a 350Z and it was excellent.
actually, we have been running one in our drift car for 2 years.
flawless performance.
a lot tighter than a kaaz.
- irwin83r
Tomei lsds
mine clunked/chirped the inside wheel in carparks at first but changed oil and now its pretty good.. still clunks a little.
other than that... love it
- Hellmun
- Vehicle: NB8B - Turbo
Tomei lsds
With the Royal Purple Max gear mine still chirps like crazy. They're very tight...I love mine as well.
- colster3
Tomei lsds
Thanks guys
Looks like it might be the go! By the way, even the standard lsd in my road car (NCLE
) causes a protest from the tyres on tight lock - especially when cold
- irwin83r
Tomei lsds
wont worry you then
just make sure you get the backlash and mesh set properly when you install it, dont just chuck the new bits in and go do some drifting
Tomei lsds
colster3 wrote:Thanks guys![]()
Looks like it might be the go! By the way, even the standard lsd in my road car (NCLE) causes a protest from the tyres on tight lock - especially when cold
How much can you get them for and where as I may also be interested in buying one.
Neil
SP Race Car
RS Clio
ML 300
RS Clio
ML 300
