Turbo Exhaust
Woo
Vehicle: 10AE - Turbo
Turbo Exhaust
Postby Woo » Wed Oct 29, 2008 10:45 pm
Who's got what on what sort of turbo and where from?
Currently I run a 2.5" on a GT30/71R and have found that I've reached the limit of the exhaust. Looking for options :idea:
Very slightly modified 10AE #2562 ..... one of 149 in Australia :wink:
Race what you brung ..... And hope you brung enough
Turbo Exhaust
Postby Okibi » Wed Oct 29, 2008 11:47 pm
3" always seems to be the standard on more powerful turbo setups.
How much power are you making with your 2.5" exhaust? :mrgreen:
mx52nv
Purple Porsche Eater
Turbo Exhaust
Postby mx52nv » Wed Oct 29, 2008 11:55 pm
HKS GT2535 on 20psi with a 2.5" exhaust.
mx52nv
Turbo Exhaust
Postby mx52nv » Thu Oct 30, 2008 12:40 am
THE REAL BORIS wrote:Obviously
:mrgreen:
Woo
Turbo Exhaust
Postby Woo » Thu Oct 30, 2008 6:43 am
Okibi wrote:3" always seems to be the standard on more powerful turbo setups.
"Obviously" you havent looked in the Garage Okibi hahaha :D
Lets just say, not enough :mrgreen:
The cast AVO dump that I have is very restrictive too. Does anyone have a 3" dump coming off an internally gated turbo on an AVO cast manifold? I've had a bit of a look and there doesnt seem much room between the firewall to fit a 3".
Bazz
ampz
Vehicle: NA6 - Turbo
Turbo Exhaust
Postby ampz » Thu Oct 30, 2008 8:56 am
I have the HKS GT2535 on the 1.6 with a 2.5 in exhaust running 8psi (boo, I'll get that EBC working this weekend).
As for the T3 is it the 5 bolt flange on the rear?
If so I have one of these that is being matted to a GT2554 on a bottom mount manifold (jeez I'm lazy though, I've only tacked together the outside primaries on the mani.
That will flow on to a 3 inch exhaust. Possibly tapering down to 2.5.
Huh?
blackster
Turbo Exhaust
Postby blackster » Thu Oct 30, 2008 9:41 am
Woo wrote:Looking for options :idea:
Chasing every kw possible?
3" turboback exhaust including divorced wastegate 3" downpipe
Previous
04' MX5 SE.
02' MX5 Classic ed.
Woo
Turbo Exhaust
Postby Woo » Thu Oct 30, 2008 10:25 am
Nice bit of kit Blackster. 8)
Looks like your turbo takes pride and place in the top of the engine bay. There is no way that that would fit and AVO setup.
If you were really chasing everything you'd be looking at a 4" with a screamer pipe, but unless the turbo is huge, it's overkill.
I like the v band adaptor idea ampz, although it takes up space that could be used for the bend. It does make fitting a heck of a lot easier though :D
cheers
Bazz
blackster
Turbo Exhaust
Postby blackster » Thu Oct 30, 2008 2:04 pm
Woo wrote:Nice bit of kit Blackster. 8)
I would love to say that its my exhaust, but its not. Its off a yankee MSM, work was done by Tim shore. If I was chasing big power, keeping it street legal and price was not a factor, then thats I would be looking to get.
Screamer pipe, decat and 4" :shock:. I can imagine the fun you will have, when it comes to emissions testing.
Previous
04' MX5 SE.
02' MX5 Classic ed.
Novice1
Turbo Exhaust
Postby Novice1 » Thu Oct 30, 2008 10:03 pm
Garrett T28 turbo, 2.5 inch Magnaflow Cat back exhaust.
168.3kw atw on 12 psi.
Cheers Novice1
Woo
Turbo Exhaust
Postby Woo » Thu Oct 30, 2008 10:13 pm
blackster wrote: I can imagine the fun you will have, when it comes to emissions testing.
Emissions testing? ..... whats that?
Have you ever tried to get a standalone certified? Avoiding detection and saving it for the track is the key 8)
Good numbers Novice, is that an AVO manifold?
Ampz, are you going to run the extra bank of injectors? is that what you ment by tacking on the primaries?
PASHN8
Turbo Exhaust
Postby PASHN8 » Fri Oct 31, 2008 1:05 am
Baz, what ECU are you using in the MX?
- 2005 MX-5 SE
http://www.dinography.com.au - From the ground
http://www.skysight.com.au - From the air
Novice1
Turbo Exhaust
Postby Novice1 » Fri Oct 31, 2008 5:38 am
AVO stage 2 manifold, 550cc injectors, plus a few other goodies.
Cheers Novice1
ampz
Turbo Exhaust
Postby ampz » Fri Oct 31, 2008 1:29 pm
Single injectors at the moment. 370cc on 6psi atm (the electronic boost control died) :cry:
I'm making a bottom mount manifold using the flange off the original extractors (1.6).
I've put about 2 hours into it now (started 2 months ago) :oops:
I've tack welded in spots the primary bends off the manifold heading down to the collector. That's it!
When it's finished (hopefully before the car is extinct)
I'm hoping for it to look like this :mrgreen:
Huh?
Sean
Turbo Exhaust
Postby Sean » Sun Nov 02, 2008 8:06 pm
Lookup Ryno (lowmiata on here).
He has made a custom dump for his AVO based set-up and I'm sure he could build you one quite similar.
When I had the big turbo and dump on mine I cut away some of the "ledge" that comes out from the fire wall to allow more room for the dump. It's not structural and my engineer was OK with it - Just be sure to check how far you intend to cut, it could get ugly if you cut too far back.
Matt from Hi-Tech Modifications in Sydney has also made some sweet dumps for MX5s, he made one of my old set-ups for the big turbo and also made the one currently on Steve Gosbees hi po NA6 turbo.
