CAM BELT more questions
grump
Postby grump » Mon Dec 29, 2008 4:44 am
Mate I've taken the easy way out. Richard at MX5Plus has his Mechanic doing mine ,as well as all the associated things, i.e. water pump ,crank seal , adjuster e.t.c. At the same time
i'm getting tie rod ends, ball joints, and NA8 front brakes fitted. Being a short nose motor i wanted to make sure that I had someone that knew what they were doing working on it.
I would have liked to have done it myself, but like an idiot I opened my mouth and told my wife that the extension to the rear veranda would be finished over xmas. To be Quite honest I'm a bit more comfortable working with timber than the inner workings of an engine
adamjp
Postby adamjp » Mon Dec 29, 2008 8:26 am
I always mark up the pulleys with a silver paint pen before I disconnect anything, but I've done this job a few times already so have found some tricks.
Yes the cam belt drive at the top marker (12 o'clock), the cam gears at I and E respectively. Release the belt tension pulley and rotate the cam drive clockwise around to the 2nd mark (at about 10 o'clock) and then tension the cam belt and lock in the tension pulley.
I find a 22mm (?may be 21m?) socket on a ratchet handle very useful for turning the engine.
Adam
Postby fastfreddygassit » Mon Dec 29, 2008 8:48 am
adamjp wrote:I find a 22mm (?may be 21m?) socket on a ratchet handle very useful for turning the engine.
It's a 21mm for the NA8 motor.
I just did mine yesterday when I change my crankshaft seal.
As has been mentioned above, I just white mark the cam belt on the I and E marks and make sure that the crank pulley is on TDC.
Then I just line it all up again for re-assembly.
easypeasy :mrgreen:
wun911
Postby wun911 » Mon Dec 29, 2008 5:10 pm
soz nube question is cam belt aka timming belt?
plz take pics along the way, I want to do mine soon...
every ounce counts
Postby Regie » Mon Dec 29, 2008 5:29 pm
wun911 wrote:soz nube question is cam belt aka timming belt?
sure is.
just take yours out completley. might save some extra weight :P
grump
Postby grump » Mon Dec 29, 2008 5:43 pm
Check alignment, if it still squeels ,Supercheap have some spray that is ment to stop squeels. I've never tried it ,just noticed it amongst the 1000 different types of spray cans they have
SuperMazdaKart
Postby SuperMazdaKart » Mon Dec 29, 2008 6:36 pm
cleanout the alternator pulley of any leftover rubber in it?
fattima
Postby fattima » Mon Dec 29, 2008 9:11 pm
Make sure the water pump pulley bolts are done up correctly. Don't ask me how I know :oops: :oops: :oops:
Postby 93_Clubman » Mon Dec 29, 2008 10:23 pm
John, good to hear it all went well!
