Extractors Glowing Red
- TieNN89
Should I be worried?
I went up Mt Cootha (for those that know) thru the back where Channel 10 ABC is not the lookout way
Anyway I went up Mt Cootha in 3rd gear doing erh cough speed limit around the 4000-5000rpm if i recall correctly
stopped infront of ABC had a look under my bonnet and i noticed a bit of the extractor was glowing red
not the whole extractor but where the extractors go from 4 to 2
Should I be Worried?
My factory water temp gauge was sitting where i usually sits
- TieNN89
Heres the bits where I saw it go red tonight not much went red tho
- greenMachine
Just keep that aircon line away from it.
Ask me how I know
, or, better still, don't...
Ask me how I know
- TieNN89
greenMachine wrote:Just keep that aircon line away from it.
Ask me how I know, or, better still, don't...
mmm not asking how you know but what was the results
any tips on how to keep the aircon line away?
AZNTieN wrote:greenMachine wrote:Just keep that aircon line away from it.
take it out
AZNTieN wrote:Anyway I went up Mt Cootha in 3rd gear doing erh cough speed limit around the 4000-5000rpm if i recall correctly
4-5000rpm in 3rd equates to 50km/hr??!!
- TieNN89
- adamjp
No problem.....glowing red is normal when you work the engine hard at, er, cough, legal speeds, cough.
There is a classic advert from the very early seventies of the E49 Hemi six pack (245cubes with 3 x 45mm Webers) on the dyno in italy as they tuned the webers and the extractors were bright red. They only made 140 E49s, try finding one now.
Adam
- Hellmun
- Vehicle: NB8B - Turbo
See I'd expect it on a turbo car or on a dyno when there's no airflow at all. However going up a hill on just 4000-5000rpm. I've ran the car for 20 minutes at a time on the track and not seen any glow. That's never going below 4500rpm the whole time either. Usually the glowing infers a turbulent spot I thought.....
- TieNN89
i'll make sure i bring my camera next time and take a snap while its glowing red
Hellmun wrote:See I'd expect it on a turbo car or on a dyno when there's no airflow at all. However going up a hill on just 4000-5000rpm. I've ran the car for 20 minutes at a time on the track and not seen any glow. That's never going below 4500rpm the whole time either. Usually the glowing infers a turbulent spot I thought.....
At a track you tend to be doing higher speeds for the revs than on a mountain. High revs + low airspeed = hot. Probably nothing to worry about.
- Fuzzlet
I was able to get the dump pipe and rear housing to glow on my NA (Running an SP manifold + turbo)
- madboy
headers are wrapped, if the heat can't dissipate then its going to get allot hotter, unless they are stainless i wouldn't be to worried
- TieNN89
yep there wrapped with DEI branded stuff
there mild steel
when i got my exhaust done the exhaust shop said he doesn't recommend stainless on extractors because they crack due to heat etc etc
so i went the mild steel and stainless the rest
i shoulda HPCed it :[
anyone know how much it cost
i just don't like the down time :[
there mild steel
- Regie
- Vehicle: NC - V8
heres a pic of my extractors after a hour of dyno time a few years ago (crappy phone camera)
