SP spark plugs
- mazlot
- Daz
SP spark plugs
I think the popular choice is (NGK) BKR7E11, the 7 has something to do with temperature and I think the stock ones are 5. I changed mine over to this model in iridium years ago and they seem good... no issues.
Silver SP - PSS9, 1:10:58
- blackster
SP spark plugs
Daz wrote:I think the popular choice is (NGK) BKR7E11, the 7 has something to do with temperature and I think the stock ones are 5.
The heat range refers to how much heat a spark plug is capable of removing from the combustion chamber. A spark plug with the proper heat range will insure that the tip will maintain a temperature high enough to prevent fouling yet be cool enough to prevent pre-ignition.
Previous
04' MX5 SE.
02' MX5 Classic ed.
04' MX5 SE.
02' MX5 Classic ed.
- bigdog
- King of the kennel
SP spark plugs
6's are the standard SP plug, most of us run the 7s, if you've upped the boost you can run 8s - Dave uses these in his. 5s are way too hot a plug for an SP. As I understand it from the dyno tests done on MX5s there is no performance benefit in running iridium plugs, just a longer plug life. Given the cost I would go (and have) the BKR7E11 route and change them more often.
- Garry
SP spark plugs
What they said, 7's, though Mazda will probably want you to fit 5's or 6's.
- Woo
- Vehicle: 10AE - Turbo
SP spark plugs
Depends on the boost you're running.
6's are good with a good tune (ie standalone), otherwise 7's for up to 15 psi. You may need to close the gap if you run 7's (0.7 mm).
If you're running bigger boost go for the 8's but as suggested check for fouling (0.7-0.8mm)
Bazz
Bazz
Very slightly modified 10AE #2562 ..... one of 149 in Australia
Race what you brung ..... And hope you brung enough
