Looking for some black rims, 15" - questions
- Hammer
Have you check the various "Show Off Your Rims" threads? There bound to be some black rims in those thread.
Otherwise, play around on the Wheel Wizard from Tempe Tyres website. There are a few black rims on 15" for the MX5. But more on 16" and 17".
Click here for the link that will take you straight to the Search.
- Matty
http://www.mx5mania.com.au/product1353.htm
Black - check (but look glossy, not matte)
"Light weight" - check (no idea what the actual weight is though)
cheap - check.
width - 7", which is perfect for a 195
strength - NFI, but a few people use em as track rims I believe...
cheap - check.
Those are the exact wheels I have on my car (see my garage thread http://mx5cartalk.com/phpBB-3.0.2/viewtopic.php?f=57&t=30857&p=446772#p446772)
no spacers used and in the photos the car is fitted with 205/50/15 though my next set of tyres will be 195 so the speedo is accurate again. The rims are very durable, I (and a few others) use the same on my 2F racecar as well.
Julian
Julian
- feel_ixx
- rossint
I got a set of these:
http://michaelautoparts.com.au/p/241/15 ... _73.1.html
Cheap chinese wheels but I've been happy with them.
6.9kg a wheel.
6.9kg a wheel.
- Matty
FMS01 wrote:Those are the exact wheels I have on my car (see my garage thread http://mx5cartalk.com/phpBB-3.0.2/viewtopic.php?f=57&t=30857&p=446772#p446772)
Julian
Do you know what the offset is? Or the weight?
- Hammer
Matty wrote:http://www.mx5mania.com.au/product1353.htm
I hope these aren't Rota Wheels clones. Here are before and after photos of a similar style from Rota. To read thread, click here
Before
Appy some kilowatts later....
- Steampunk
feel_ixx wrote:You can always paint your 15" rims black
If you buy a high-quality spray paint that etches as you spray, then it's a good budget option, without having to sand and prime the wheels.
go into the Garage Chat section and check out the NB8A wheels I have.
Hammer,
The Mania wheels are not Rota's, they are good wheels.
I have a set with RE55S tyres as my track rims and have had no problems at all. They are also quite popular with the 2f guys and if they can't make them fail I reckon they must be ok.
Jake
Jake
- 16bit
Hammer wrote:Matty wrote:http://www.mx5mania.com.au/product1353.htm
Before
Appy some kilowatts later....![]()
that was on a 500hp civic around the ring on semis though - for normal driving they should be fine.
- feel_ixx
feel_ixx wrote:
HAHAH!
everyone should know that rota's are flocked, and have no structual rigidy.
just like friends not letting freinds roll on nankangs!
Blue94t wrote:Hammer,
Jake
I have the same wheels for the track. Do you run them with hub rings? or are the studs carrying the weight? I am wondering whether I need to get some hub rings.
hub rings are a must! the studs alone should never support the weight of the car, there're only to hold the wheel on the hub.
