Hrmmm, that's unusual...
Caffeine
Postby Caffeine » Tue Feb 24, 2009 8:54 pm
Driving home this evening, all seems good, then I turn a corner and went to accelerate, and the car didn't seem to like that, seemed to be running on 3 cylinders!
So I pull over into a handily placed Repco carpark, poke around, plug wires seem ok, car runs just as badly with the intake pipe disconnected so it's not blocked.
So I go into Repco and buy some new spark plugs, put them in, no effect :(
At the moment I suspect plug wires, and tomorrow I'll put a new set in to see if it helps...
SuperMazdaKart
Postby SuperMazdaKart » Tue Feb 24, 2009 8:58 pm
yeh sparkplug leads. it's not that unusual really.
Caffeine
Postby Caffeine » Wed Feb 25, 2009 7:15 am
Just had a lightbulb moment, so I headed down to the car this morning, and it started fine, which leads me to believe it's temperature related.
The NB8B has coil on plug ignition, and hence only 2 ignitors / coils, and I think one or both of these is not handling the heat...
So today I'll see if Mazda has a new set (or if it will be an 8 week wait like every other part on the car)
Caffeine
Postby Caffeine » Wed Feb 25, 2009 7:17 am
bigdog
King of the kennel
Postby bigdog » Wed Feb 25, 2009 1:13 pm
Try swapping them from another car first caff - they're bloody expensive if you don't need them. You're welcome to try mine if you can get up here to get em...
Caffeine
Postby Caffeine » Wed Feb 25, 2009 1:27 pm
Some knowledgeable people have suggested the CAS may be the problem, so I poured some water gently on (what I think is) the CAS and the car seemed to idle slightly smoother for a few seconds, so that may be the culprit.
If that doesn't work I might make the trek up to your place John, thanks for the offer! :D
Caffeine
Postby Caffeine » Wed Feb 25, 2009 1:34 pm
Caffeine wrote:Some knowledgeable people have suggested the CAS may be the problem, so I poured some water gently on (what I think is) the CAS and the car seemed to idle slightly smoother for a few seconds, so that may be the culprit.
Hrmmm, it seems there are two cam angle sensors, and 1 crank angle sensor, which do I order I wonder...
Garry
Postby Garry » Wed Feb 25, 2009 2:31 pm
One is cam angle sensor the other a crank angle sensor. Niether are in the piccies. The one your after fits on the top rear of the valve cover, the other attaches to the lower front part of the engine. The one you are after is the cheaper one. I have 2 spare coils, a cam and crank angle sensor if you'd like to borrow them?
wun911
Postby wun911 » Wed Feb 25, 2009 2:38 pm
I also have two spare coil over plugs, mazda wanted like $370 each :shock:
At the moment the cam angle sensor is out of stock at mx5 parts uk.
Does anyone know the torqe spcs of the bolt that holds down the cam angle sensor???
If feels feels like the bolt is very hard to turn, I just dont want to break anything...
every ounce counts
Caffeine
Postby Caffeine » Wed Feb 25, 2009 3:02 pm
Garry wrote:One is cam angle sensor the other a crank angle sensor. Niether are in the piccies. The one your after fits on the top rear of the valve cover, the other attaches to the lower front part of the engine. The one you are after is the cheaper one. I have 2 spare coils, a cam and crank angle sensor if you'd like to borrow them?
That would be great Garry! I don't want to go an spend hundreds of dollars on stuff that isn't broken to find out which part is!
I just (slowly) poured 500ml of iced water over the one on the top of the valve cover, didn't appear to help. Doesn't mean it's not the bad guy I guess. :(
May I come and pick up the parts tonight?
Caffeine
Postby Caffeine » Wed Feb 25, 2009 8:07 pm
Ok, 1/2 fixed!
Thanks to Garry, I was able to swap in plug leads, coil packs and cam angle sensor (in that order)
The cam angle sensor seemed to make a slight improvement, and after about 5km the idle is back to normal.
The car still feels like it's struggling to breath, and sounds like it has a pod filter on it. So tomorrow I'll take off the intake and see if there's any blockages etc
So some progress, once I get all the problems nailed I'll swap my bits back in, buy the replacement for the offending part, and give Garry's parts back to him :)
bigdog
King of the kennel
Postby bigdog » Sat Feb 28, 2009 9:15 am
Any solution Caff? Or are you still on the pushie and wondering why? :D
Caffeine
Postby Caffeine » Sat Feb 28, 2009 12:11 pm
I'm taking the car in to top tune next week, I've run out of ideas!
rjastra2
Postby rjastra2 » Sat Feb 28, 2009 12:33 pm
Did you replace the leads?
They can be heated affected... work ok when cold then play up as the engine heats them up.
JBT
Postby JBT » Sat Feb 28, 2009 1:03 pm
Checked for an induction leak?
Users browsing this forum: Google [Bot] and 1 guest
