SS clutch line?
wun911
SS clutch line?
Postby wun911 » Mon Mar 30, 2009 3:01 pm
I plan to do clutch install over easter break, I would like ss clutch line they used to be sold at mx5 parts but no more.
I can get it made up like I got my ss break lines made up, but I have to take the line out so they can make it the same length and fittings etc (dont want to do this). Who has one? feel the difference? cost? where from? fittment issues?
every ounce counts
RG.net
SS clutch line?
Postby RG.net » Mon Mar 30, 2009 3:54 pm
SS = heavy
go CF lines, LAWL!
wun911
SS clutch line?
Postby wun911 » Mon Mar 30, 2009 5:02 pm
lol no cf but it will be as short as possible like my break lines...
every ounce counts
SS clutch line?
Postby Mr Morlock » Tue Mar 31, 2009 1:08 pm
I would not have thought it will make any difference to move from the standard set up. For brakes I have heard that rubber may swell when applied ie hydraulic pressure and steel will not. Whether this is discernible for a clutch is another thing and it costs money. Wt is not an issue.
wun911
SS clutch line?
Postby wun911 » Tue Mar 31, 2009 2:11 pm
I'm quite weak and feable and I'm not really a fan of a heavy clutch pedal.
But if ss lines give a more smooth shifting experiece I'm all for it.
(I noticed a more smooth shift after bleeding the clutch fluid)
I just want to try ss lines and see what happens.
every ounce counts
SS clutch line?
Postby Mr Morlock » Tue Mar 31, 2009 4:46 pm
A heavy clutch has to come from the clutch itself. A standard clutch will take less force to operate than a sports clutch which will have heavier springs in the pressure plate. A clutch specialist should be able to confirm if changing of lines has a force benefit. When I changed my clutch, albeit for normal driving, I was advised by MX5 Mania not to bother with the Exedy sports clutch as I too, really get tired of a heavy clutch.
zoomzoom
Vehicle: NA6 - Turbo
SS clutch line?
Postby zoomzoom » Tue Mar 31, 2009 7:54 pm
I think the benefits of the ss line are that you get to get rid of the silly stock one which loops over the top of the firewall and back again, via a set of loops, making it easier to bleed and also getting it away from the extractor/turbo heat on the passenger side.
You could try mx5plus, I think they may have been getting some done at one point, can't remember if there was to be a few for stock or not?
Tim
Fatty
SS clutch line?
Postby Fatty » Tue Mar 31, 2009 8:39 pm
zoomzoom wrote:I think the benefits of the ss line are that you get to get rid of the silly stock one which loops over the top of the firewall and back again
yep the oem clutch line is damn silly, it snakes around all over the place. i guess they made it that way so they could use the same parts on left and right hand drive cars.
wun, i would think you could just visit your local brake store such as ABS or whoever, and get them to make a line up for you. i did a slight mod on my clutch line when i fitted the new slave and it cost me about $20 for them to mod the existing line, re-flange it and fit a new nut. i reckon if you plotted out your new, shorter path, decided on what fittings you need, they could custom make something for you. i can't see it being difficult or expensive.
wun911
SS clutch line?
Postby wun911 » Tue Mar 31, 2009 10:23 pm
ohh shorter path does sound good.
Will look into it.
every ounce counts
Woo
Vehicle: 10AE - Turbo
SS clutch line?
Postby Woo » Tue Mar 31, 2009 10:29 pm
When it comes to taking the motor and trans out as one, that loop over the top is a godsend.
Bazz
Very slightly modified 10AE #2562 ..... one of 149 in Australia :wink:
Race what you brung ..... And hope you brung enough
tuned_to_fly
SS clutch line?
Postby tuned_to_fly » Wed Apr 01, 2009 7:31 pm
SS clutch line?
Postby Okibi » Wed Apr 01, 2009 7:38 pm
I noticed them this morning too. :mrgreen:
Woo
SS clutch line?
Postby Woo » Wed Apr 01, 2009 8:12 pm
Someone organise a group buy on these ..... please, pretty please
wun911
SS clutch line?
Postby wun911 » Wed Apr 01, 2009 8:45 pm
wait before we do GB someone ask if its the same for both left and rite hand drive cars???
I dont want to fail like i did in the clutch master cylinder GB.
I sent them an e mail asking them for a 10% discount if we order 5 of them to Australia.
And I asked them if it fits both left and right hand drive cars.
every ounce counts
