kaaz lsd - anyone got one
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Thu Apr 17, 2008 11:48 am
next question - where to get it installed in brisbane. I have quote from a while ago for about 400 dollars.
Postby orx626 » Thu Apr 17, 2008 2:13 pm
16bit wrote:next question - where to get it installed in brisbane. I have quote from a while ago for about 400 dollars.
Diff & Gearbox Industries
2/280 Newmarket Road, Wilston, 4051
Ph: 3356 8397 or 0417 704 942
Contact: Steve
neil d
Postby neil d » Sat Apr 19, 2008 7:22 am
Thanks for the link.
That is a hell of a lot cheaper than the $1500 I have been quoted here.
Neil
SP Race Car
RS Clio
ML 300
Postby Okibi » Sun Apr 20, 2008 4:54 pm
wazman
Postby wazman » Wed Apr 29, 2009 5:33 pm
I just bought a KAAZ 1.5 way for my NB ...... i'll get it put in at central diffs in morrabin.... once i get it out of the car :? ...... is there a thread that shows how to get the drive shafts out of the diff ???....Or can anyone tell me how? 8) ... i'm used to the bolt on half shaft nissan style :roll:
ilovedrift.com
corners
Vehicle: ND - Supercharged
Postby corners » Wed Apr 29, 2009 7:41 pm
I bought shecks setup from his car and put it in mine and can backup that its really smooth and quiet but still binds time after time which is great!!
Hellmun
Postby Hellmun » Wed Apr 29, 2009 7:58 pm
From memory on the NB it actually pulls out, the older NA's were a bolt arrangement with stub axles. It's been that long since I took the pumpkin out of my car to get the Tomei diff put in though....
wazman
Postby wazman » Thu Apr 30, 2009 8:24 pm
I got the diff out no worries.
I paid $1200 for my kaaz 1.5 way from "RMS" performance parts in melb, He had it in stock 8)
I took it and the housing to "central diff's", who are now in fairview st in springvale, to get the back lash set.
Here's a handy link if you are about to pull out your diff and don't really know how.... clicky below
http://www.mx5ireland.com/members/srigley/writeup/Installing%20a%201800cc%20diff2.htm
ilovedrift.com
irwin83r
Postby irwin83r » Fri May 01, 2009 7:07 pm
looked into the tomie 20 clutch pack 2ways??
hi octaneracing syd can get em.. sure theres others
wazman
Postby wazman » Sat May 02, 2009 10:48 pm
Central Diff's (springvale,melb) charged me $250 to put the kaaz mech center in with new bearings and set the backlash.....i didn't bother with new seals because mine looked ok..... dropped it off and picked up the next day......
Got dizzy doing figure 8's to run it in...... good times :mrgreen: ...... remember once you've done the figure 8's you have to change the oil.
so diff budget stands at.....$1530..... :roll:
Kaaz 1.5 way diff center $1200
center install/set backlash $250
extra can of Kaaz diff oil $80
Has dramatically changed the way the car drives! so much better from a performance point of view....... from a daily point of view its very tolerable.... only slight chatter when cold and turning tight under power...... I'm very happy and hanging back end out every chance i get ! :twisted:
ilovedrift.com
16bit
Postby 16bit » Sun May 03, 2009 10:39 pm
yeah they really help rear end grip. from about 20kph i can floor it in first in the wet and get NO wheelspin - thats with 160ish wkw!
Damo
Postby Damo » Sun May 03, 2009 10:59 pm
wazman wrote:Got dizzy doing figure 8's to run it in...... good times :mrgreen:
Haha, that was good fun. For me, the most suitable place to do it was in a quiet carpark right behind a police station. I had no doubt that I'd get asked wtf I was doing, but I figured that I wasn't going to be doing anything illegal so, why not! I got summonsed over after about 20 minutes, but just explained that that was the safest place to do it and the officer agreed and let me get back to it.
NB8A (2000 Highlight Silver), KU36, Kaaz LSD, QFM A1RM, Mazda Competition engine/differential mounts, Town & Country cat-back.
Alex
Postby Alex » Mon May 04, 2009 3:53 pm
16bit wrote:yeah they really help rear end grip. from about 20kph i can floor it in first in the wet and get NO wheelspin - thats with 160ish wkw!
:shock: what tyres?
16bit
Postby 16bit » Mon May 04, 2009 6:38 pm
toyo r1r - they are amazing in the wet i have found.
philz
Wheel guru
Postby philz » Mon May 04, 2009 6:45 pm
R1R are excellent tyres better than RE001, they will be my next set.
