Engine Build - Not sure if it will be NA or Turbo!
Juffa
*TURBO* Engine Build - Now with some rebuild Pics
Postby Juffa » Sat May 23, 2009 11:02 pm
It's been over 24 hours since the last post... don't keep us in the dark!!!
J
daffyflyer
Postby daffyflyer » Mon May 25, 2009 10:10 am
It runs! I drove it to work!
Idles like a ported rotary though, dunno if thats Cams + stock computer or if i got the cam timing a little wrong!
Also need to check if the gearbox is bolted in OK, it bounces up and down under power
Point remains though, we built a motor and it hasn't blown up yet, and it makes the car move! :mrgreen:
Postby bruce » Mon May 25, 2009 10:51 am
Luv those geeky pix of you guys. Car-nerds.
daffyflyer
Postby daffyflyer » Mon May 25, 2009 11:07 am
bruce wrote:Luv those geeky pix of you guys. Car-nerds.
Oh Tragicly so!
daffyflyer
Postby daffyflyer » Mon May 25, 2009 11:24 am
It plays on your nerves having built your own engine though.. i keep wanting to duck into the carpark and check if the crank has fallen out while its parked or something!
daffyflyer
Postby daffyflyer » Mon May 25, 2009 2:35 pm
Ahhh.. THATs why the gearbox wobbles.. it had dropped a bolt out of the PPF, guess i didn't do it up tight enough! :oops:
daffyflyer
*TURBO* Engine Build - Now Running - video soon!
Postby daffyflyer » Tue May 26, 2009 9:52 am
Bugger... It leaks oil, appears to be from the rear seal or sump, either way its engine out again...
Oh well i know what im doing for the next few weekends then :evil:
EDIT: Having look at the photos of the build, looks like its the sump rear seal not the crank seal
adamjp
*TURBO* Engine Build - Coming out to fix oil leak :<
Postby adamjp » Tue May 26, 2009 10:48 pm
The seal between the sump and the block at the back can be a PITA to get in right. Spews oil all over the inside of the bellhousing. It can be easily fixed with the engine in the car. But get a tube of aluminium friendly silicone before you go in.
Don't ask me how I know this.....but there is a gearbox drop in your immediate future.
Adam
daffyflyer
Postby daffyflyer » Wed May 27, 2009 9:56 am
adamjp wrote:The seal between the sump and the block at the back can be a PITA to get in right. Spews oil all over the inside of the bellhousing. It can be easily fixed with the engine in the car. But get a tube of aluminium friendly silicone before you go in.
Yes, we had loads of trouble getting it in right, it kept kind of... squeezing out of the back of the engine.
Oooh... so you ca get to it with the gearbox off, im assuming the sump needs to drop too does it?
And then just attack the join with sealant?
PS - Thanks muchly Adam, this may have just saved me a LOT of work
adamjp
Postby adamjp » Thu May 28, 2009 7:03 pm
1. Remove Gearbox.
2. Remove Flywheel (not so easy, but doable).
3. Back off the bolts at the rear of the sump (makes it easier, but your sump won't drop down - it is glued on remember).
4. Fit/refit the seal in question and goop it up good with the silicone. I think I ended up basically building a wall of silicone that sealed the gap.
5. Put it all back together.
I did it in 4 hours one night with the help of my father. Your time may vary.
Adam
daffyflyer
Postby daffyflyer » Fri May 29, 2009 8:01 am
Sweet, although to look at it, the rear sump bolts are quite loose. might torque them up and see if it stops leaking first lol :mrgreen:
Postby bruce » Fri May 29, 2009 12:44 pm
That's my solution to all leaks - give it another half turn with the spanner to fix it!
Fuzzlet
Postby Fuzzlet » Mon Jun 01, 2009 9:17 pm
How much oil is it loosing? If its any help, that engine's previous build leaked oil from the beginning...
daffyflyer
Postby daffyflyer » Tue Jun 02, 2009 10:01 am
Fuzzlet wrote:How much oil is it loosing? If its any help, that engine's previous build leaked oil from the beginning...
Err... about an entire sump a week lol, its like you park it after a drive and a puddle appears :P.
Got the cam timing sorted though, and even without the ECU it runs sweet, Idles ok @ 1200 rpm, and goes hard (even with my current self imposed 5krpm redline)
Only issue is that after driving for a while it seemed to have some kind of ECU or ignition related fail, would idle fine, but opening the throttle would give no more power than idle, and it would drop on to 3 cyls. any hints what to check?
Fuzzlet
Postby Fuzzlet » Tue Jun 02, 2009 7:25 pm
Well if ur running stock cams with the standard ecu that might have something to do with it, otherwise I cant help ya
Users browsing this forum: No registered users and 29 guests
