Sloppy Gearstick
PT
Sloppy Gearstick
Postby PT » Fri May 29, 2009 12:06 pm
Hi all,
Picked up our new car this week - an 01 NB8B. Something I've noticed with it is when the car is in gear, the gear stick is really sloppy, has heaps of left-right and up-down play. When out of gear though it feels quite tight.
Is this just a case of changing some bushes?
Any help appreciated.
Paul
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
Fatty
Sloppy Gearstick
Postby Fatty » Fri May 29, 2009 12:32 pm
does the car have a short shifter installed?
in the ball / fulcrum part of the shifter, there is a slot with a plastic insert , there is a pin that sits in this slot. on the cheaper short shifters,the pin wears against the crappy plastic insert and the slot gets larger and wider than it's suppsoed to be, so the stick starts to slop around a bit.
not sure if this is the same problem you're having, but that's what mine's like anyway.
Sloppy Gearstick
Postby Okibi » Fri May 29, 2009 12:43 pm
PT
Sloppy Gearstick
Postby PT » Fri May 29, 2009 12:50 pm
No short shifter installed.
Okibi, found that thread also - just bumped it back up - there is actually no resolute to say if that fixed it or not. Hopefullyt someone can shed some light.
Having only picked it up on Wednesday night, I've had no tinker time with it, so will pull it all apart on the weekend anyway.
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
bigdog
King of the kennel
Sloppy Gearstick
Postby bigdog » Fri May 29, 2009 1:02 pm
Most likely cause is the bolts securing the lever to the top of the gearbox - they are notorious for coming loose. Undo to rubber boots and have a look at the them.
Sloppy Gearstick
Postby Okibi » Fri May 29, 2009 8:21 pm
Or the rubber shift boots are damaged. :mrgreen:
Users browsing this forum: Google [Bot] and 6 guests
