Upgrading to 2Ltr In my NA6..YEAH!
daffyflyer
Postby daffyflyer » Mon Jun 01, 2009 2:29 pm
tcoo7399 wrote:
Szemen wrote:Speaking of which, what is the maximum engine size you can go from stock? Is it an incrase of 10%?
Topic is a little old but it could be useful to know.
Based on an NA; In NSW its 4L for naturally aspirated, 2.6L for forced inducted, and if its a rotary you double the cc's to get the equivalant piston engine dispacement. I assume Victoria would be pretty similar.
So 1uzfe or rb26dett then? :mrgreen:
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Mon Jun 01, 2009 4:40 pm
no way, NA 20b triple rotor for me. 400hp and 10krpm. or possibly a cosworth dfv 3L v8 (dfr edition with 640hp at 11krpm). Or even better a cosworth dfx 2.6 twin turbo v8 with about 840hp.
Postby bruce » Mon Jun 01, 2009 5:05 pm
tcoo7399 wrote:Based on an NA; In NSW its 4L for naturally aspirated, 2.6L for forced inducted, and if its a rotary you double the cc's to get the equivalant piston engine dispacement. I assume Victoria would be pretty similar.
That doesn't sound quite right - you can't just drop a 4.0lt Lexus v8 donk straight into a 5 legally.
GS
Postby GS » Mon Jun 01, 2009 5:19 pm
16bit wrote:no way, NA 20b triple rotor for me. 400hp and 10krpm. or possibly a cosworth dfv 3L v8 (dfr edition with 640hp at 11krpm). Or even better a cosworth dfx 2.6 twin turbo v8 with about 840hp.
Haha. I can picture it now. "Honey, im going down to the shops in my MX-DFV to pick up some milk". Twenty minutes later you're still sitting in the garage while 2 mechanics shovel buckets of dry ice into your radiator, another 2 mechanics are hovering around the with the remote starter, and the engineers are busy on the laptops trying to load the right start procedure for you!!
1989 NA6
Postby bruce » Mon Jun 01, 2009 5:27 pm
16bit wrote: 840hp.
The MX5 would instantly flip over due to the torque of the motor.
Postby bruce » Wed Jun 03, 2009 11:43 am
No worries. I remember years ago there was chat regards getting an engineer to sign off on the 5 to weigh a lot more so you could squeeze a bigger motor legally into it. It would have to weigh 1300kgs (we're talking factory weights here) to get a 4lt Lexus donk into it.
And then when you try to get it registered at VicRoads, they would call their own Engineer and then politely kick you out the door!
16bit
Postby 16bit » Wed Jun 03, 2009 12:49 pm
i will have it de tuned and with a starter motor. will be perfectly drivable above 8k!
