Gotta change the oil again, it had about a 60km oil change when i pulled the motor a second time, but after about 300km I think its time to change it again and make sure its not full of metal shavings!
1red5 wrote:Get an oil filter wrench (those circular ones with a handle) from Supercheap from $10-$20
it's still tricky, but persist with it and put in a few swears and it'll come loose
Fuzzlet wrote:Taking off the driver's side wheel and the mazda filter wrench work well for me
Andrew - since you've gotten so good at pulling the engine out, u could always remove it every 5000kms to change the oil
bensale wrote:Is the na8 more difficult to access than the na6? I just reach in from the top of the engine, loosen and take it off by hand. Too easy. Of course as Manga Blue said it can't be too tight or then in becomes a little more difficult.
Users browsing this forum: No registered users and 17 guests
