Estimated cost to fit NA8 to 1989 NA6
ako
Postby ako » Mon Jul 20, 2009 8:00 am
Hi everyone,
I'm looking to purchase an NA MX5 in the next few weeks. I can find lots of 1989 - 1991 models available, most with 200K+ km's and with the known SNC problem. My preference is a '94 NA8 but can't seem to find a good one.
My question is;
If I buy a 1989 NA6, how much will is cost to 1) buy an NA8, 2) Have it rebuilt (as standard), 3) Fit it to the NA6 (with any upgraded components as required)?
I would love to hear any war stories from those who have done this :)
1989 NA - sold!
2004 SE - sold!
2010 NC roadster
StanTheMan
Postby StanTheMan » Mon Jul 20, 2009 8:59 am
just buy the 1.8
rebuilding a motor you can spend $4K very easily
so 6-7K for the NA 6
NA8 motor $650
rebuild to factory specs $4K another option would be a newer BP engine and/or transplant the SE engine & drive line.
clutch
headers
ecu
installation $1K-2K
Rear NA6 diff upgrade $650- $1900.
all in all you will gain 5-10 RWkw....My Almost stock NA6 has the same output as some of the lower NA8's but you will always have more torque in a 1.8. Even if you have it rebuilt according to factory specs......doesn't garrantee more HP.
If you are going to buy a NA6 leave it as is & mod it.......with 2.5 k you can get up to 90RWkw.....
or just buy Zanes 94 Clubman viewtopic.php?f=73&t=34177&start=0....
I haven't actually done it....but I'VE THOUGHT ABOUT IT LOST OF TIMES
this is of course looking at it in an economical way.If you don't mind throwing money at it because you can & want to......
by all means
$5K-6K on top of purchase price
Postby Mr Morlock » Mon Jul 20, 2009 2:40 pm
If you want to do something based on best economics then buying a good car at market price is the best choice. Buying a car that needs work requires a well below market price and an ability or facilities to do the work yourself. You will pay up to $100 per hour for someone to do work for you. Like car resto's few people ever see the $ spend back.
Postby Jeo » Mon Jul 20, 2009 2:50 pm
Speaking as an owner of an NA8 engined NA6, don't bother. Just buy the NA8 in the first place, it will save you so much time, effort and money that it isn't funny.
If you had already bought the car i would still say keep the 1.6 unless it needed replacing anyway, and even then it wouldn't be a cut and dry decision.
ako
Postby ako » Mon Jul 20, 2009 8:01 pm
Thanks guys for the advice. I thought the cost would outweigh the benefits.
I'll check with Zane but it looked like he sold it in his last post.
1989 NA - sold!
2004 SE - sold!
2010 NC roadster
StanTheMan
Postby StanTheMan » Thu Aug 20, 2009 8:14 am
NA8 will always have more power if you go FI. its probably the batter way to go.
but comparing standard NA6-NA8 there is not a real lot of difference in it. Nice NA8's are as rare as hens teeth now and usully big $
Its easier to mod an NA6 because you have all the NA8 parts that fit.
In my opinion the NA8 is worth having because you have all those bits that you will most likeley want to have as an NA6 owner.
timk
Postby timk » Thu Aug 20, 2009 9:25 pm
Diff, brakes, bracing, R134A air con.
Need I say more? 8)
corners
Vehicle: ND - Supercharged
Postby corners » Fri Aug 21, 2009 12:42 pm
saboteur wrote:Diff, brakes, bracing, R134A air con.
Need I say more? 8)
I was going to go there but didnt.... :lol:
Users browsing this forum: No registered users and 24 guests
