Torsen owners
philz
Wheel guru
Torsen owners
Postby philz » Wed Jul 29, 2009 11:48 am
StanTheMan wrote:4.1:1 which is standard anyway.
Is that the Torsen 1?
What if i was to put a 3.9 Torsen 2 in there (normally used for 6speed), what would happen?
Sailor
Torsen owners
Postby Sailor » Wed Jul 29, 2009 12:03 pm
JBT wrote:The tests above won't necessarily work on a Torsen diff because, if one wheel loses traction, it will behave the same as an open diff. Clicky
Ahhh Ok, Cheers.
Never played with a Torsen
Rob
Steampunk
Torsen owners
Postby Steampunk » Wed Jul 29, 2009 12:18 pm
http://www.torsen.com/
If you put in a lower ratio, ie. 3.9 as opposed to 4.3, then the rear wheels turn slower and thus your speedo will be out, so you will need to swap the speedo-sender on the gearbox to compensate.
StanTheMan
Torsen owners
Postby StanTheMan » Wed Jul 29, 2009 12:34 pm
I'm not sure which torsen you are fitting. Most likely a torsen 2 right?
the torsen itself will probably not come with a crown wheel anyway. They'll most likley be using your existing one. Which is a 4.1:1 unless its been changed.
if its a 2nd hand torsen it may have a crown wheel fitted to it.
your acceleration is slightly less agressive. your geares will wind out a little longer.
I've gone from 4.3:1 to the 4.1:1 I quite like it.....but its at the expense of slighly quicker accelaeration
Torsen owners
Postby sliq » Wed Jul 29, 2009 2:31 pm
just try doing burnouts :lol:
