My era of MX5 ownership! Twilight Blue NB8A
toymx5
Postby toymx5 » Fri Jun 19, 2009 12:27 am
That's for that, I'll have a look at the weekend and check it out :)
My little 'Toy' thinks she's actually a Ferrari !!
Postby hks_kansei » Fri Jun 19, 2009 12:36 am
not a problem.
be prepared though, you may need to get into some very awkward positions to reach properly.
also remember to check the other drains on the windscreen, when the door is open you will see a rubber seal on teh windscreen frame, on the side will be a little flappy/scoop bit (about where the triangle glass tip is), there will be a hole at the bottom of the scoop thing which directs water down through the rubber seal (it's hollow) and out in the door sill, check it's clean too, it will probably be fine though, it's not as easy for dirt and stuff to get into the windscreen seal.
Postby hks_kansei » Mon Jun 22, 2009 10:31 pm
ok, still looking around for wheels, I'm not anywhere near making a purchase, just seeing what's out there that catches my eye.
so far there have been two more that have caught my attention:
both manufactured by Performance Alloy Wheels (an Aussie company)
the first is called "V-Tek"
15x6.5
the next is called "Challenger"
15x7
any ideas on these ones?
price and quality?
Postby sliq » Mon Jun 22, 2009 10:38 pm
mxhevn had a set of challengers FS abotu a month ago. search function here you come!
Postby hks_kansei » Mon Jun 22, 2009 11:50 pm
you guessed well, I just searched :P
they look great on the NA, but I'm unsure of how they would look on an NB, I still need to jump onto photoshop and test.
the V-Tek is nice and more modern looking (I would spray the centres in graphite colour or something)
but the Challenger is more unique, but being a more classic design may look out of place on the NB.
Postby hks_kansei » Fri Jul 10, 2009 12:17 pm
ok, today's updates:
#1: Finally fitted the gear shift surround, fits well, looks damn good.
Image Image Image
fits nice and flat once screwed down, screws were sexy little countersunk ones too!
Image Image
#2: Gave engine bay a dodgy clean, just dusted and cleaned off most of the coolant overflow (not from spillage, but gauge has never showed overheating?)
dusty intake.
clean intake
dried coolant overflow residue
cleaned off somewhat.
#3: Discovered that I may have a wheel bearing on the way out :evil: I'll have a proper look at it during the MX5 mod day on the weekend.
Postby Jeo » Mon Jul 13, 2009 5:40 pm
New sig looks awesome :)
Simple and works really well
Postby hks_kansei » Mon Jul 13, 2009 6:15 pm
thanks it's just a resize and crop of one of the pics from the dodgy day.
which reminds me this thread needs an update!
as you may see in an above post, I mentioned a possible wheel bearing.
well it turns out it wasnt a wheel bearing, I was running low on power steering fluid :shock:
thanks to Darrin though it's all fixed and no issues or noises! woot!
wazman
Postby wazman » Thu Jul 16, 2009 3:05 am
hks_kansei wrote:ok, still looking around for wheels, I'm not anywhere near making a purchase, just seeing what's out there that catches my eye.
15x6.5
15x7
price and quality?
Becareful....... The challengers may not suit the car. The wheel you choose will "make" the look of the car. I Cant stress how important it is to get it right.
I cant tell you what wheels to buy because everyone has different style.
Easiest way to work out the best wheel for you is to follow these steps....
1. Find pictures of CAR's that have after market wheels that you like the look of (not just mx5's) try to pick cars with similar style/shape eg...the FD mazda rx7 i think has similar bulging curves...your just looking mainly for the style of car you like the look of eg- hot4's look, JDM, retro, blingy, racecar.... a good place to start looking is http://forum.jdmstyletuning.com/showthread.php?t=3016
2. Look at the supporting mods that make the car and its wheels look good... eg lowered, bodykit, flared/rolled guards, bolt/glue on guard flares, colour of the wheel (pay attention to colours not so much the colour of the car but more so the wheel, this can also make or break the look....)
How far are you willing to go and how much are you happy to spend to achieve the look you like??? It may be more than just wheels you have to buy to make your car achieve the look you want.
3. Learn about "offset" .....the same wheel in different offsets can look great or horrible and do the same thing to your car !!...... the "challenger" is one of them! If you can be bothered sorting through the crap there much to learn here >>http://www.nissansilvia.com/forums/index.php?showtopic=271829
Buddyclub make some nice wheels in decent sizes......Though the "performance" superlite is my favorite.
nice shifter surround....really perks up the console 8)
ilovedrift.com
philz
Wheel guru
Postby philz » Thu Jul 16, 2009 10:03 am
True, wheels make or break a car.
RG.net
Postby RG.net » Thu Jul 16, 2009 2:35 pm
I agree,
i dont think challengers would suit the NB body lines at all, they do look decent on an NA, but not spectacular.
Postby hks_kansei » Thu Jul 16, 2009 2:58 pm
basically what I want mainly is the following:
15"
max 7" wide (max I can legally go)
sit under guard without the need for cutting or any major changes (minor guard rolling is fine)
as for style, I would like a bit of a lip, not necessarily massive dish like MXHEVN, but a bit of a lip.
I'm also leaning towards the exposed bolt look of 2/3 piece wheels as well and sort of an old fashioned look too.
I quite like the Konig rewind and Konig BBomb (yes, knockoffs I know blah blah)
the only issue is that the Aussie Konig dealer is Ozzy Tyres or something in Sydney, who seem more concerned with "can you fit 20" chromies on it and paint it in Candy paint?"
Postby hks_kansei » Fri Aug 21, 2009 11:58 am
I started on my plan for the Reflectors.
Before images:
fresh out of the box from Perth (thanks Marcus) and just given a quick wash.
During:
Lettering removed via wetsanding with 400grit paper. It was very easy, and only took about 5mins for each one.
how they now sit:
the 400grit has indeed made them dull, but they still reflect.
If you wanted you could continue on with smoother papers and get them clear again, but for my purposes the dull cloudyness is what I want.
tune in next time when I attack them with a coat of primer and wetsand with 800grit.
oh, btw, which are front and rear? one pair have a foam backing on them, are they for the front or rear?
philz
Wheel guru
Postby philz » Fri Aug 21, 2009 12:03 pm
What does it do?
Postby hks_kansei » Fri Aug 21, 2009 12:10 pm
philz wrote:What does it do?
the sanding?
the sanding removes the raised letters off the reflectors so that dirt and stuff cant collect in there.
however I am going to be painting my reflectors to the car's colour.
Users browsing this forum: No registered users and 23 guests
