Pwr Steering Fluid Spillage?
CapitalF
Vehicle: NA6 - Turbo
Postby CapitalF » Fri Sep 18, 2009 9:50 pm
It appears since adding turbo I'm having pwr Steering fluid overflow all round the canister. I'm confident it was not overfilled. Is this heat related or ?
Thx
Peter
90 Silver Roadster 1.6 + GT2554, large IC, MS-PNP, lightened flywheel, HD Clutch, 2.5" exh, Teins, Whiteline, etc etc
Garry
Postby Garry » Fri Sep 18, 2009 10:33 pm
Is the O-ring still on the power steering dip stick?
On the SP Mazda Motorsport relocated the power steering resevoir quite close to the turbo to make room for the new airbox. I haven't heard anyone complain about power steering fluid leaks. I know there are no leaks in my car.
CapitalF
Postby CapitalF » Fri Sep 18, 2009 11:45 pm
Think so but will look more closely. Doesn't seem loose to insert/ remove.
Thx.
CapitalF
Postby CapitalF » Sat Sep 19, 2009 3:54 pm
O ring is still there. The spillage is onto the top of the canister tho??
Maybe there is crack in the plastic that's not obvious.
I should prob drain the system and remove canister to check it more closely & connections to it. Yes? The air intake may be rubbing and have a pinhole there too? It isn't supposed to be a high pressure system tho is it?
Any other suggestions?
Peter
Postby manga_blue » Sat Sep 19, 2009 8:53 pm
A few of us in Vic have had power steering fluid overflow after track sessions. Just seems that working it hard for 15-20 minutes causes it to spray out the top. We just wipe it up and go on.
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Sun Sep 20, 2009 8:04 am
It is probably overheating...you can try fitting a power steering cooler, Davies Craig make one...I always fit them to the race cars.
CapitalF
Postby CapitalF » Sun Sep 20, 2009 7:54 pm
Thx guys. Just looking to see if I should be looking more closely or not. Will look into the cooler.
Peter
Postby manga_blue » Sun Sep 20, 2009 11:16 pm
CT
Postby CT » Mon Sep 21, 2009 2:14 pm
And use a synthetic fluid.....
Postby bruce » Mon Sep 21, 2009 2:39 pm
I do like the little socks the ricers put on top of their fluid reservoirs (soaks up any leaks).
