stock shock replacemnt for NC with Eibach springs
lucifuge
Postby lucifuge » Tue Sep 29, 2009 8:38 am
I have Eibach pro-kit springs installed on my NC. I'm not 100% sure at this stage, but I think I may need to replace my stock shocks. Can anyone recommend a good replacement to go with Eibach springs on the NC?
@ndrew
Postby @ndrew » Tue Sep 29, 2009 8:44 am
What makes you think your stand shocks require replacing?
You could pick-up some some Koni or Mazdaspeed shocks from eBay US.
lucifuge
Postby lucifuge » Tue Sep 29, 2009 8:49 am
@ndrew wrote:What makes you think your stand shocks require replacing?
On rougher roads, I'm getting a chattering from the rear passenger side. For last two weeks or so, I've assumed it was something loose in relation to the PRHT or similar. It only just dawned on me that maybe it's the rear passenger shock absorber. I looked a minute a go and cant see any leakage of fluid. It's just a hunch and I could be way off. Car has just done 30,000ks and half of that with the Eibach's. But actually now I think about it, I dno't think I'm hearing it when the roof is down. Any easy way to rule out if the shocks are not the problem??
Charlie Brown
Postby Charlie Brown » Tue Sep 29, 2009 9:27 am
If you're still under warranty I'd be taking a little trip down to Mazda. They may try the "it's not our fault the shockie is gone, it's the aftermarket springs" trick but as the springs are the same as Mazdaspeed and they warrant that in the US you could argue against them.
Otherwise just go to Good-win Racing http://www.good-win-racing.com/Mazda-Pe ... nsion.html and get the Tokico adjustables.
lucifuge
Postby lucifuge » Tue Sep 29, 2009 10:12 am
Charlie Brown wrote:If you're still under warranty I'd be taking a little trip down to Mazda. They may try the "it's not our fault the shockie is gone, it's the aftermarket springs" trick but as the springs are the same as Mazdaspeed and they warrant that in the US you could argue against them.
Are you running the Tokico shocks, or have experience with them? How good are they?
Charlie Brown
Postby Charlie Brown » Tue Sep 29, 2009 5:43 pm
lucifuge wrote:Are you running the Tokico shocks, or have experience with them? How good are they?
Not running these, just going on all the reports out of the US.
I've a set of second hand Eibach coilovers that haven't been fitted because of moving house a week or so ago and I'm still trying to make up my mind about either fitting them or I'll head off to Josh at Wholesale suspension and get a new set from them.
The reason I'm heading towards coilovers is because I can adjust the car to the height I want and then harden the shocks to keep it off the rear bump stops when fully laden. My current Kings are about 5 - 10 mm to low. Great for the track but a bummer in the real world with a passenger and a boot full of gear, with the car sitting about 65mm off the ground fully laden.
As you already have springs at the right height, the Tokico adjustables would be the best bet. The Koni's drop the car another 10mm, which will be too low if the Eibach springs are down 35mm already.
Sailor
Postby Sailor » Tue Sep 29, 2009 6:32 pm
Big benefit with the Tokico is the remote adjuster cable that you can fit to the rears so you don''t need to start cutting holes in panels to get at the top of the shock.
Rob
lucifuge
Postby lucifuge » Tue Sep 29, 2009 7:53 pm
Another possibility I just thought of. The noise is a sort of chattering type noise on quite rough roads that continues until road smooths out, could it be the bushings on the rear swaybar that need lubing? They are Whiteline. I am not sure if this is a known issue or a remote possibility?
JBT
Postby JBT » Tue Sep 29, 2009 9:48 pm
Have you checked the sway bar end links for looseness or wear?
lucifuge
Postby lucifuge » Tue Sep 29, 2009 10:59 pm
JBT wrote:Have you checked the sway bar end links for looseness or wear?
nope, if the ends are lose in a significant way...is it obvious?
JBT
Postby JBT » Tue Sep 29, 2009 11:38 pm
There should be no looseness when you grab hold of each one and try to move it about. Easy to reach the rear end links from behind the wheels.
JBT
Postby JBT » Wed Sep 30, 2009 7:51 am
Photo of driver's side link (red arrow) for clarification is attached.
Sailor
Postby Sailor » Wed Sep 30, 2009 8:25 am
Indeed..I had this problem when I had my new bars installed...Quick tighten with a ring spanner and all was well again....thick paint.
Rob
lucifuge
Postby lucifuge » Wed Sep 30, 2009 10:52 am
Sailor wrote:Indeed..I had this problem when I had my new bars installed...Quick tighten with a ring spanner and all was well again....thick paint.
What alerted you to this problem? Sound or other?
Sailor
Postby Sailor » Wed Sep 30, 2009 10:59 am
Just a clatter.
I could make it happen by driving over a speedhump at an angle so the bar came into play.
As the OP said, I then crawled under the car with weight on the wheels and could feel a slight movement.
Remember, we're only talking about the clearance of a bolt in a hole so it isn't much to feel.
Rob
Users browsing this forum: Google [Bot] and 13 guests
