Track, Street or both
Novice1
Postby Novice1 » Thu Oct 22, 2009 9:21 pm
I, have a set of Toyo Proxes 17" * 215 * 40 ZR17 87W on a turbo mx5, which are wearing well and I am very happy with.
Looking to track the car occasionally. Is it best to have two sets of wheels, one for road and one for track? If so, what track rims, tyres, sizes should I be looking at? My car can be set for low boost 6psi which is drivable, or high boost 12 psi which is a bit of a monster for me.
I, would suspect on track low boost would be more than enough for my capabilities, so recommendations centred on packages for same is what I am seeking.
Cheers Novice1
Steampunk
Postby Steampunk » Thu Oct 22, 2009 10:28 pm
You know my answer regarding the set of 4 circular anchors that you have on at the moment :mrgreen:
Me, since my car is not a daily driver (like yours), I would steer towards just one set of wheels and road tyres that can withstand track abuse;
1) less hassle swapping around
2) you don't wear through tyres either on the track or street-driving too quickly since it's not your daily
3) If you do get track-oriented tyres, there's a fair chance they will perish due to time (ie. lack of use) rather than chewin them on the track, hence money wasted... unless you take to the track in a bigger way than the 4-6 times a year with the club.
4) have you checked out the prices of dedicated "R" spec tyres recently? :P
My current recommendation for street/track tyres are the Kumho Ecsta XS (KU36). Excellent value at around $190 per tyre for 16" & 17".
I know your preference regarding wheel style, but I found something that may peak your interest. Check your PM :wink:
NMX516
Postby NMX516 » Thu Oct 22, 2009 11:08 pm
Ron my advice would be to get a second set of wheels and tyres for the track. Especially more so if you plan to use the car on the road fairly regularly. I would not expect to see more than a few thousand kms out of a set of R-spec tyres on the road. At their price that gets very expensive very quickly on a regularly dríven street car. Further more, road tyres cop a flogging on the track, especially with the power you've got. I'd be wanting as much grip as money could buy in your car :)
...I'll have a set of NB8A rims for sale soon... 8)
PUR157
Postby PUR157 » Thu Oct 22, 2009 11:16 pm
Just something piquing my curiosity... why do you always put a comma after your "I"s novice1? :?:
compulsion? proper grammar?
Oneness of Man and Machine
Novice1
Postby Novice1 » Fri Oct 23, 2009 7:04 pm
PUR157 wrote:Just something piquing my curiosity... why do you always put a comma after your "I"s novice1? :?:
Poor grammar.
Cheers Novice1
Novice1
Postby Novice1 » Fri Oct 23, 2009 7:12 pm
NMX516 wrote:Ron my advice would be to get a second set of wheels and tyres for the track. Especially more so if you plan to use the car on the road fairly regularly. I would not expect to see more than a few thousand kms out of a set of R-spec tyres on the road. At their price that gets very expensive very quickly on a regularly dríven street car. Further more, road tyres cop a flogging on the track, especially with the power you've got. I'd be wanting as much grip as money could buy in your car :)
thanks for the advice. What sort of rims do you have. At the moment my car is *$(%)$ not track bound, leaking coolant again:( Spent four hours last weekend changing hoses only to find more coolant on my garage floor.......aarghhhhhhhhhhhhhhhhhhhhhh.
Not a lot of coolant, but not something I want leaking on the track.
Cheers Novice1
NMX516
Postby NMX516 » Fri Oct 23, 2009 10:10 pm
The NB8A rims mentioned are just standard MX5 NB8A rims - 15 x 6.5. I use Toyo 888's on them.
