Can anyone show pics of their oil cooler install?
Uncle Arthur
Dodgy Award Benefactor
Postby Uncle Arthur » Mon Nov 16, 2009 5:08 pm
I'm considering installing an oil cooler - just need some pis how others here (who have also done so) did their install.......
Russellb
RIP Nov 2014
Postby Russellb » Mon Nov 16, 2009 5:25 pm
Where I put mine in the clubman
also have the race car cooler in the same spot
My ClubmanRebuild
MX5 SE Rally car is HERE :)
SuperMazdaKart
Postby SuperMazdaKart » Mon Nov 16, 2009 6:12 pm
Not mine, nor is it an MX-5, but might provide some interesting ideas.
Adam_NAclubman
Postby Adam_NAclubman » Mon Nov 16, 2009 11:58 pm
Diff cooler or oil cooler on a 911?
Postby Okibi » Tue Nov 17, 2009 12:20 am
SuperMazdaKart
Postby SuperMazdaKart » Tue Nov 17, 2009 12:26 am
Hrm, custom radiator with integrated oil cooler on the side.
Adam_NAclubman wrote:Diff cooler or oil cooler on a 911?
Haha, is actually a Familia GTR setup for rallying. I'd say it's most likely a rear diff oil cooler (though they don't usually need it).
http://www.rally24.com/rally-cars-for-sale/rally-car-2752.html
Benny
Postby Benny » Tue Nov 17, 2009 8:36 pm
If you take off the front clip, you will see a big piece of white, honeycombed plastic.
Just mount it on the top of that and cut a couple of slots in the clip for fresh air to get in, just above the number plate.
Easy.
Uncle Arthur
Postby Uncle Arthur » Tue Nov 17, 2009 8:41 pm
Benny wrote:If you take off the front clip, you will see a big piece of white, honeycombed plastic.
Easy.
Let's just say for a moment I DON'T want to take a dremel the bodywork of my car......... although I do like the oil/radiator combo.
How much was that?
fattima
Postby fattima » Tue Nov 17, 2009 10:52 pm
This is what I did,
In the front panel there are some captive nuts already in place, made some alloy brackets that aligned with the holes and my oil cooler. Pretty simple to do.
Oil cooler lines run down side of radiator, I ground out then smoothed off the radiator side bracket to give clearance for the lines.
d-mag
Road Track Rally
Vehicle: ND - Turbo
Postby d-mag » Wed Nov 18, 2009 6:12 am
Nice! I like that one. Yours too Dave.
MX5 Wanted. SE or NC (forced induction preferred :twisted: )
wun911
Postby wun911 » Wed Nov 18, 2009 3:04 pm
where do you get the rad from or is it a custom job??
every ounce counts
fattima
Postby fattima » Wed Nov 18, 2009 4:54 pm
The cooler was on the car when I got it but was mounted differently. I believe it is a MX5parts UK one, don't ask me how much it weighs :wink:
