new transmission
Steampunk
new transmission
Postby Steampunk » Sat Nov 28, 2009 2:14 am
can't help you with pricing, but I can say that (once again unless I am grossly mistaken) no Australian delivered NA8's came in auto.
So unless you dont mind buying a JDM, stick with manual NA8.
broady
new transmission
Postby broady » Sat Nov 28, 2009 2:52 am
Honestly I wouldn't bother unless you were going to do the swap yourself...
Just wait for the right car to come up -- is the best advice I can give.
人馬一体 NA8
6/5/2010
StanTheMan
new transmission
Postby StanTheMan » Sat Nov 28, 2009 8:46 am
chap on here was going to do it....he's not posting much on here anymore.
I figure the change over would be around $5k. The gearbox itself would be the cheap part. You could then also try to sell the automatic gearbox to try to recoup some money.
MX5HVN did have someone lined up to do the conversion.....I don't recall a figure. he may have kept that for himself. ..... but this $5 k figure is an estimate for labour , fittings, gearbox, diff ratio & so on.
you just have to hang around. A car for your needs will come up eventually. But then you have to be ready to just snap it up.
new transmission
Postby Jeo » Sat Nov 28, 2009 10:52 am
My NA6 started out life as an auto and as the other have said; if you're not doing it yourself, don't bother; if you haven't bought the car yet, don't bother. Far easier to wait for the right car to come up rather than trying to bodgy something else to fit.
new transmission
Postby bruce » Sat Nov 28, 2009 10:58 am
Give me your Auto 5 and $5K, and I will turn it into a manual 5. It may be a different car though...
new transmission
Postby 93_Clubman » Sat Nov 28, 2009 1:27 pm
And wasn't the engine in one or more of the autos detuned slightly? Low comp pistons or similar?
GP
new transmission
Postby GP » Mon Nov 30, 2009 2:21 pm
I think that's a myth, No evidence found as yet
Graham
Matty
new transmission
Postby Matty » Mon Nov 30, 2009 2:30 pm
GP wrote:I think that's a myth, No evidence found as yet
NA6 auto was apparently detuned, different cams.
new transmission
Postby 93_Clubman » Mon Nov 30, 2009 2:56 pm
Googled: miata automatic detuned engine - the 2nd link was from page 45 paragraph 1 of Brian Long's book, Mazda MX-5 Miata:
http://books.google.com.au/books?id=qCP ... q=&f=false
Alternatively, Randy Stocker's old Solo Miata engine page says:
"The automatic transmission version of the 1.6 DOHC engine has lower compression pistons to 9.0:1 and the camshafts have less duration. These changes were done for the automatic version to gain torque at a lower rpm and minimize detonation from the torque eating trans."
http://www.solomiata.com/Mx5Engine.html
Users browsing this forum: Google [Bot] and 4 guests
