Joe's NA6
- broady
Re: Joe's NA6
yep, torque wrenches aren't really designed to undo bolts
人馬一体 NA8
6/5/2010
Re: Joe's NA6
Agree with Broady. Using them like this can send them out of calibration as well. Atleast you got some where with it.
89' Roadster - Sold
'04 SE - Sunlight Silver.
- Jeo
Re: Joe's NA6
Ahh, did not know that (obviously
New socket first thing Saturday morning and I'll try again with just the breaker bar and the ratchet then.
Re: Joe's NA6
Careful with a ratchet, ive broken a few using them as a breaker bar
. Breaker bar and a mighty pole seems to deal with decently tight bolts. Soak it in WD-40/RP-7 as well. I forget what its called but there's a special white grease that you can buy, chuck it on the stuff your putting together and it'll come apart easy as next time you pull it apart. I figure if its good enough to use on aircraft its perfect for cars
89' Roadster - Sold
- Jeo
Re: Joe's NA6
I broke a 3/8 drive 17mm socket the other night.
Got off work early today so came home to have a crack at it again. Stopped off and bought another 3/8 drive 17mm socket. Broke that. Went back and bought a 1/2 drive socket set (had been looking for an excuse for one of these for a while) and some WD40. Let is soak for about half an hour while I made lunch. Hit it with the 1/2 drive breaker bar and while you still wouldn't consider it easy, it came out.
Both front corners done, rear passenger done, rear drivers is half out.
Just need the bolt that holds the bottom of the shock out, then to put the last coilover in. Yay!
Re: Joe's NA6
Yeah you've gotta use beefy stuff on the important bolts. Glad to here you got them off. Try find some of that anti sieze grease incase you need to rip it apart again. Works wonders.
89' Roadster - Sold
- Jeo
Re: Joe's NA6
And they're in!
Quick drive around the block to make sure all was well. About to go out for the evening so will have to finalise the height tomorrow, not particularly even at the moment.
- Jeo
Re: Joe's NA6
Haven't touched it since Friday so the height is still well uneven. Will get that finalised this week as I've got an alignment booked in on Wednesday.
- Mr nanotech
Re: Joe's NA6
Are these easy to adjust the height on? I've always wondered with coilovers, how do you know you are lowering them evenly the whole way around?
Re: Joe's NA6
yeh there easy as to lower.. to make it evenly just have a tape measure and it should work out fine if u know simple maths
Re: Joe's NA6
nanotech wrote:Are these easy to adjust the height on? I've always wondered with coilovers, how do you know you are lowering them evenly the whole way around?
The BR series are "easy" to adjust height:
1. Jack the car up on one side (driver or passenger side)
2. Loosen the lower ring lock of each coilover
3. Screw the coilover upper ring lock to the desired height (up or down)
4. Tighten the lower ring locks
5. Lower the car to the ground so that the jack is no longer supporting the car - this is the "settling height" of the car on the springs
6. Measure how much you'd like to adjust the height by
7. Repeat 1
8. Measure the distance between the upper and lower coil ring locks, you need to adjust this by the amount measured in step 6
9. Repeat 2-4 until the distance measured in step 6 is achieved
10. Measure the front and rear coilover ring distances
11. Copy the measured distances to the other side of the car
12. Lower the car and you're off (to get a wheel balance)
Keep in mind that the MX5 should by 0.5" higher in the rear than the front for best handling according to Keith Tanner from Flyin' Miata ( See http://forum.miata.net/vb/showthread.php?p=4674848 post #321 )
I added the BC Racing BR series coilovers a couple of weeks ago to my car and am very happy with them now they're installed.
- Jeo
Re: Joe's NA6
As above, they are simple to adjust (like all coilovers I'd assume).
Also had to cancel the alignment as I really wasn't up to driving in my incredibly sickly/drugged state. Withdrew my entry to the track day on Sunday too
- broady
Re: Joe's NA6
The proper way is to get the car corner weighted
人馬一体 NA8
6/5/2010
- Guran
- Vehicle: ND - 1.5
Re: Joe's NA6
broady wrote:nanotech wrote:Are these easy to adjust the height on? I've always wondered with coilovers, how do you know you are lowering them evenly the whole way around?
Yep but that's only necessary if you're doing serious track stuff. Or if you like the look of uneven wheel/body clearances.
Users browsing this forum: No registered users and 26 guests
