Check out this example recorded with a Vbox, but it works the same way with the delta-t display:
Guran wrote:Also it seems that you can't use preloaded split files and have to press a button while crossing the start/finish line! That'll be fun when strapped in with a harness. I'll have to relocate the PBox a bit closer.
Guran wrote:No I haven't tried it yet. You can still preload the split files from the SD card in Laptiming Mode, but it appears this is not possible in the new Predictive Mode (according to info in the new User Manual and on the Racelogic forum). You have to press one of the arrow buttons when you cross the start line, and that then overwrites the split file you've loaded. I'll post some feedback after I test it out at Wakefield next week. It's a bit clumsy IMHO but ... meh ... it's a free upgrade (on a three year old product!) and should still be very useful. So I'm not complaining.
Guran wrote:I occasionally stick mine in the glovebox and use the external antenna. But only when the scrutineers get anal retentive. I'll be putting it on the windscreen in the bottom-right corner. Should be able to reach it with the harness tight.
